What Amp For Two 12" type R Alpine Subs??
Old 02-09-2009, 12:59 AM
EmperorJJ1's Avatar
Originally Posted by Spun
A cap only works if you have the current there to start with, if your drawing more power than your car can dput out then a cap is not only not going to help you but in the end put more of a strain on the electrical system.
At 2300 watts my system draws over twice what the alt can put out but no cap is going to help that, not even a Kinetik HC 1800 totally stoped the light dim, I have 2 of the big 3 done but have a feeling the 3rd isn't going to stop it either so I am having an alt built from the ground up by a local guy, its costly but the only way to get a 200+ amp alt for these cars, short of a problematic 2 alt setup.
If your drawing less than 105 amps then a cap might help, but IMO there just a plecebo, they make you think there working but really there just for show
hey i take offence to that... lol jk which is the last of the big 3 you have left?
Old 02-09-2009, 01:09 AM
09BlackLT's Avatar
I'm new to the upgraded stereo systems, so I'm just getting a few parts ready before I start mine. I have helped a friend with his, so I hope I know what I'm doing. This many be dumb, what are the big 3??
Old 02-09-2009, 01:17 AM
EmperorJJ1's Avatar
upgrading/adding on to 3 important electrical wires
alt-battery power wire
battery ground
alternator ground
Old 02-09-2009, 01:21 AM
09BlackLT's Avatar
Ok thanks man!
Old 02-09-2009, 01:45 AM
crumba's Avatar
i had a similar setup in my 06 ss i had a p5002 rockford fosgate amp and 2 12" p2 subs hooked with a line level converter to the factory head unit. it sounded great except for the fact i had 500 watts bumping the trunk and almost knocking my spoiler off. rockford amps are underrated that same system was in my blazer and it blurred my vision. my point is 1000 watts is way to much for the trunk of any car you will hear a rattling tin can even with some dinomat a suv is like a bass tube anything will sound good but car trunks don't. if you do have to get over a 1000 watt amp you might have to get a bigger alternator and battery if its under 1000 i might get a cap depending on the car. caps do put a strain on the alternator but so do chevys auto headlights. it takes about 140 amps from your alternator to run a 1000 watt amp. and you need a good battery optima yellow tops are $200 and they are made for car audio. most car alternators are around 120 to 150. for a capacitor you need 1 ferrit for every 500 watts. you want an amp to mach the subs rms at least. some company's overrate the amps and some underrate them 1st i would find out how much power your alternator puts out then go from there
Old 02-09-2009, 02:02 AM
EmperorJJ1's Avatar
lol just asw an fyi with enough sound dampening you can get rid of the rattling. only thing that rattles on my car is the rear bumper and thats with 3000w rms
Old 02-09-2009, 03:04 AM
stinkyfisherman's Avatar
I cant wait till im all done! no music is driving me crazy.
Old 02-09-2009, 03:34 AM
EmperorJJ1's Avatar
lol it will be worth it in the end... if it makes you feel better i did drive in my car with pretty much nothing but a drivers seat for a while
Old 02-09-2009, 10:13 AM
Thats what Im doing right now I have nothing but the front seats and my headliner. I can already hear a difference in road noise even with everything pulled
Old 02-09-2009, 01:52 PM
Spun's Avatar
I only said it cuz you told me how hit and miss it was
For the big 3 I have the Battery grounds done (2x18" 0 guage grounds) and the Alt to block done (1 0 guage ground) and I have to do the Battery to Fuse box but I have the wire for it just trying to find time to pull the inside of the car apart and run the wire. Plus neatly hiding 0 guage under the carpet (without having it create a bulge) should prove to be fun.
Im going down the drivers side since my RCA's all run down the passenger side, but I have 20 feet of wire so I should be OK
BTW- Your's being problematic isn't like the rest of us, you work at a shop and do this for a living so if you have a problem you can fixit/have it fixed right away. I run into a problem and I'm dead in the water so to speak
Old 02-09-2009, 07:47 PM
  #36
09BlackLT's Avatar
Thanks guys, can't wait until I get these subs thumping. Now I just need to find a box to put them in!
Old 02-09-2009, 07:48 PM
  #37
Go with a custom box for them, prefabs sound like butt.
Old 02-09-2009, 11:47 PM
  #38
EmperorJJ1's Avatar
lol i know plus my car can be down for 2 weeks and it not be too bad. let me know if u need help with the wire... your going to want to run it along side the stock wires and you shouldnt be able to tell
Old 02-10-2009, 05:12 AM
  #39
Spun's Avatar
Yeah that was the plan. I was going to zap strap it right to the stock wires, just picked up some 3/4" loom so I should be good to go.
Thanks for the offer I might take you up on that
One thing, I picked up some street wires power rings to match the rest of the terminals in the car, am I going to have an issue trying to get one of these under the post in the fuse box.
Heres a picture so you know what I'm talking about
Old 02-10-2009, 05:29 AM
  #40
hymer741's Avatar
Originally Posted by 09BlackLT
Hey guys I just got two Alpine type R 12" subs today. What amp and wattage should I be looking for to power these?? Hope I can get some ideas! Thanks
Kicker 500.1
best amp EVER.... << opinion
Old 02-10-2009, 07:18 AM
  #41
EmperorJJ1's Avatar
ya that's not happening with those terminals spun. The first time i did it i had some 1/0 from a friends truck he had a ring terminal like that. with heat shrink and all but i hat to yank it. What you need is a copper lug that you will have to bend in a 90" i can take a pic if u need one i still have a short piece from that old 1/0
Old 02-10-2009, 02:02 PM
  #42
Spun's Avatar
I have some of those as well, oicked them up froma auto store at the same time I had a feeling that the street wires ones wouldn't fit.
There kinda like the ones that come on the end of the stock neg cable, just bigger
Thanks
Old 02-11-2009, 01:28 AM
  #43
EmperorJJ1's Avatar
i havent had the stock neg in my car for years so i dont remember but ya that should be it
The Rookie24
01-20-2016 05:14 PM
chefhhr
10-26-2015 10:36 PM
jimbofug007
10-02-2015 12:06 PM
c_m_shooter
09-27-2015 04:40 PM
OrangeCoba
09-25-2015 06:06 PM
Quick Reply: What Amp For Two 12" type R Alpine Subs??
