What Amplifier Should I Buy? HEEELPPPP!!!?
I am running a 10" Alpine Type E sub (RMS 300 MAX 600 ) with 2 CS65's speakers (RMS 100 MAX 300) What would be a good amp to buy? don't know really anything about this stuff I tried to figure it out but my brain just isn't made for this stuff. I want to know how many channels, rms and max watt would be best for this set up?
Since your speaker is a single 4ohm voice coil you're going to be better off running a 2 channel amp bridged. Here is my suggestion
SKAR Audio LP-100.2AB 340W RMS Class A/B 2-Chan Car Power Amp
Its a little bit over the RMS rating of your sub but you should be fine
If you dont know what how to bridge an amp just dig around that site and you'll find some handy diagrams
So no rear fill? You could run a Pure 1200.4($140 from the right dealer with warranty) which would send 80 wrms to your front stage and 220 wrms to the sub provided you run the fronts on front channels and the sub bridged across the rear. Has a very small footprint too.
