What Size Quick Splice For Interceptor?
Got my ZZP triple pod and interceptor today from Kingpin2010. Everything's great. ZZP pod doesn't fit as well as stock, but oh well.
ANYWAYS,
I bought these (Dorman/Conduct-Tite 4 pcs. blue weatherproof quick splice terminal (85462) | Electrical Wire Connector | AutoZone.com) to tap in to the pink wire on the stock boost gauge.
Problem is it's barely cutting into the wire, making no connection. What size taps/quick splice did you guys use that have the interceptor tapped into the stock boost gauge power wire? Maybe something available from AutoZone, so I can return those ones.
ANYWAYS,
