Where is the best place to ground 4 gauge wire to in the trunk of a balt
I would probably put it a little bit away from your battery actually that way your not going to have to reset any of your presets if the ground wire desides to ground out on the power terminal
Why do that? If its directly to the battery you dont have to worry about any voltage drop due to resistance.
