Whining in the Speakers
Hey guys i did some searchin but nothin answered my question. Ive got a whining noise coming through my speakers, mostlikely alternator, my question is how do i get rid of it? I was gonna re-ground the alternator and try that. Any suggestions?
Do you have any aftermarket stuff in your car? radio, speakers, amps, subs... etc.
Last edited by stinkyfisherman; 02-23-2009 at 12:00 PM. Reason: I not got teached to spellz
My speakers are hooked up to an MTX 4 Channel amp, and the amp gets its signal from RCA's from a JVC deck. I get the sound from all speakers. The Amp is grounded off at the Grounding block in the trunk
Wow I didn’t even look at my post to proof read it lol.
What side of the car are your rca's ran? I know also there is a lot of electrical noise around the radio, I have that problem too.
First up check your connections and see if anything is loose. Back to your rca's are they running parallel with any power wires if so they need to cross at a 90 degree angle so they don’t pick up noise. You can go by some ground loop isolators but that’s just a temp fix.
what kind of RCA cable did you use? is it shielded? if not switch those out first for some good quality shielded cable and you should see at least a major decrease in the whine if not totally eliminating it.
brickloaf
09-25-2015 09:10 PM
