who has had fitment problems with aftermarket hu
Mine's is an 06 but everthing works, DIC, gas guage, Speedo, Cruis, AC, heater, alarm, headlights, blinkers, and stoplights. Oh yeah, the interior lights also work. Crazy huh!! all with a freebie harness from crutchfield. Of course I don't have the steering wheel controls so that might make a difference.
Art
Art
Art
Art
Bandit i don't mean to be a pain but how far does the spacer for the dash kit allow you stick your headunit out? Because that way i could just put spacer instead of cutting anything.
Originally Posted by Bandit2941
Nah, you just need to get a steering wheel interface box from PAC (www.pac-audio.com). They're easy to hook up.
![Smile](https://www.cobaltss.net/forums/images/smilies/smile.gif)
Art
I would also need a steering wheel with the controls since mine does not have any
, but I do have a remote for the H/U though so that is just as good!!!
Art
Art
What did you guys connect your lead wire to??? I need to relocate mine. And do you still get the radio play for 10 minutes after the car's shut off or until you open the door???
Originally Posted by JPizzle
With the aftermarket radio, does your car still display whether the passenger airbag is ON or OFF?
Thanks for the info. When I was tinkering around with the different fuses I had preselected I don't think it worked for me. But I can't remeber. I'll try it again and see what I can come up with.
My car doesn't display that feature.
#37
do you think that little pocket in the dash kit is a good place to put the ipod? I was thinking about drilling a whole in that pocket to send the aux input wire in there from the deck to the ipod.
#38
I hate that pocket. All I do is throw cd's in there when I'm too lazy to put them up. Bad thing is, I have to be careful when I accelerate. I've had a few flying cd's in my car since I've put the h/u in.
#39
well i just got done installing my headunit in my car... it was a easy install and everything works great.. thanks to everyone that helped. The only hard part was getting the deck in the dash due to my deck has so many wires behind it, but finally trying to get the deck to fit i was very impressed, def sounds 50 times better than factory.
#41
yea same here i was about to give up and put the stock unit back in but finally everything went in nicely, i'm just i never have to take the headunit out for a very long time
#42
With the harness and everything I got now, all the settings on the DIC are just stuck there. So now, everytime I turn my car on, it says CHANGE OIL SOON. Is there anyway I can bypass that and reset it without havinvg to yank my h/u out just to plug in my stock stereo for a sec and reset it???
#43
#44
Maybe I should have gotten the more expensive harness. But I was told several times that my "play cds and radio that's it radio" wouldn't require the high dollar harness for the aftermarket h/u. And someone told me I wouldn't be able to change the settings on the DIC anymore. I just figured someone on here figgured out a way around that. Does anyone else have my problem??? What harness did you use Bandit???
#47
