Why do power plugs always stay hot? Any way to change this?
I'm sure this has been asked but I couldn't pull up anything in search. I'd like to know why the American manufacturers choose to leave the power plugs always hot even when ignition is off. I like how in a Japanese car when I have a Bluetooth receiver, USB adapter, etc. plugged in that it always turns on and off with the car and so it can be left plugged in all the time. In the Cobalt and pretty much every American car, they stay hot so if you're not going to be driving your car for a few days you should probably unplug it so it doesn't drain your battery. It's inconvenient...what is the point of having it this way?
Is there a simple way to change this behavior for the front plug in the Cobalt?
Thanks.
Thanks.
What if someone want's to leave a phone charging in the car while they are at work.
I always unplug everything I don't need running even in my own house. Coffee maker, toaster, microwave, etc all unplugged unless in use.
Thanks.
Thanks.
