wideband optional dimmer wire help
Ok, so I installed my glowshift wideband, i tapped into the passenger fuse panel and took the 12v current, the signal from the ignition and grounded it. The gauge comes with an optional dimmer wire that when 12v current is received it will dim the gauge. is there a fuse/wire in the passenger fuse box that i can tap into so its not soo bright at night, or what wire will work? it would have to tap into the headlights some how or a switched source that comes on with the headlights... could i use one of the wires on the dimmer switch or are those constantly on?. thanks guys.
any1?
any1?
^^ def listen to this guy. And I can vouch that he knows what he's doing with wiring, he had a base ls that had crank windows he converted to the SS power everything. He fooled me, you'd never know it was an ls lol
Anyways just tap into the dimmer that controls the insturment panel so you can dim it with the knob to the left of the steering wheel
n20saturn
09-30-2015 12:26 AM
