Will it fit?
Will it fit?
So i have seen a couple threads on our trunk dimensions and what will fit but i figure if i am going to spend a lot money on a system i should make sure that it will fit. I am looking at putting a 32 3/8" W X 16" H X 17 3/8" D(bottom) X 13 15/16" D(top). It is 2 12" Kicker CVR's. Your help is greatly appreciated.
I have that setup in my car. It will fit fine, but you will have to take the rear seats out to get it in. Its not too hard though. Just watch out for the bolt that sticks out from the top of your trunk when you are sliding them in, i cut a small piece of it off so it wouldnt scratch up by box.
I think the clearence is 17 inches high, like stated already you might have to take the back seats out to squeze it in. Those bolts are what hold the child restraint anchors in, if you don't have kids then just remove them, in any case I would take them out and put them back in after your done before I tried to cut them.
i think the lowest bolt is the seat belt bolt... i had to cut it to get my box in and you will as well. Seat must come out and the aprox size of the trunk opening height is 16
wait hold up is the whole box 32" wide or does it wedge upward
Delta coupe
09-30-2015 08:11 AM
