Wire behind stereo wrapped in foil?
Old 03-09-2014 | 07:48 PM
Britnisima's Avatar
So my front passenger side speaker only works sometimes. It doesn't cut in and out when I'm driving, but it'll work for a few days then cut out for a few days. This has been consistent for at least a month, so it's getting pretty annoying. I've pulled the panel off the door and checked the speaker itself, and pulled out the radio and checked the back connections. I noticed there was a wire that looked different from the rest. It was blue and shiny. So naturally I took a look and it's a wire that's covered with foil (silver on the inside and blue on the outside) but it doesn't connect anywhere. I'm not a pro at this, and I don't know what that wire is, but I wrapped the foil back around it and taped it up with some electrical tape to make sure it's sealed.
Here is a link to a picture of my mystery wire. View image: image
I also noticed in the past that if I'm using the aux input and charging my phone at the same time it makes this faint buzzing sound that gets louder as I accelerate. Once I taped that mystery wire up, that is gone, but if I'm switching a song I noticed I can hear that. It's weird.
I have stock everything right now.
Does anyone know what the hell that is? What it does? I've searched all over the internet and didn't
Thanks for any help
Old 03-10-2014 | 11:38 AM
EmperorJJ1's Avatar
those are the wires that go to the stock xm box. they should be connected to a small black plug. sounds like your getting a ground loop from it (i would assume the open wire with foil is for the antenna to try and boost signal but thats just a guess) You would need to tape the entire wire to ensure it doesnt ground on the HU or any other metal object
Tupp
2.2L LAP Performance Tech
01-02-2016 01:04 PM
dennis69
10-20-2015 08:39 AM
ernnyyes
10-02-2015 06:16 PM
jmelton327
09-26-2015 11:04 PM
09-26-2015 07:44 PM
