Wiring my deck, got a problem
Here is the audio wiring diagram for our car
Radio 12v red/white
Radio Ground black/white
Radio Ignition GMLAN Serial Data
Fact. Amp turn on Pink
LF Speaker(+/-) tan/gray
RF Speaker(+/-) lt. green/drk green
RR Speaker(+/-) drk blue/lght blue
LR Speaker(+/-) brown/yellow
Speaker wiring is on harness or amp
The other wiring is on harness
This Helpful?
Radio 12v red/white
This Helpful?
If you are wondering what wires on an aftermarket plug are the solid blue is remote turn on (for turning on an amp) and blue with white strip is power antennia (cobalts don't have)
Woowoo....got her in and she works like a charm, as does everything else on the car...il take pics when i can find my F'in camera, btw...the aftermarket radio doesnt come on until i turn the key to ignition (just before statring it), assumed that was normal, and when i turn the car off it kills the radio....again not big issues, just varying from the stock h/u....but the speakers sound soooo much better
That is normal for most radios. The sotock one had a timer built in that let it run for a set amout of time or until you open your door. You lose that (as you now know) when you put in a new deck. Do you know what the problem ended up being?
Yeah, i was given the wrong harness which had just so happened to fit the plug and looked somewhat like it would work, since i hadnt wired a cobalt before...either way it was a harness issue and everything works great now....accept when i go to put the new deck in it wont fit flush because the antenna adapter at the back sticks out against the metal plate thats there..ideas?
Originally Posted by slowbalt
Had the same issure becaue the deck I got left the rca's sticking way out and hit that metal support. I took an air saw and cut the top of that metal thing and then bent it down. Now everything fits great. I highly doubt that the metal thing was all that important because it isn't a very thick metal. I asked the installer at the shop I work at and he told me to do this. He said that he is having to do this more and more to the newer "all cramed together" cars.
yeah i had the same problem cept mine was plastic with a metal bar i cut the plastic out with a hot knife and the bar just unbolted it was atighe squeeze but i got a ratchet in there
#36
NoLeafClover, connect the red wire you have running to the fuse box to the sunroof fuse (whether you have a sunroof or not there will be a sunroof fuse). That will restore original functionality of the RAP (retained accessory power) and the radio will turn on in acc and not turn off until you open a door, just like stock.
#37
Originally Posted by Bandit2941
No its not normal for most radios, it has nothing to do with the radio. It has to do with the power source obtained to turn the radio on.
there will not always be a sunroof fuse...my car doesnt have one...i think if you dont have pw or pl then you have no sunroof fuse. i have been trying to find that wirein my car since last september. even have a friend that is a GM tech and brought home his tech 2 and said he cant find one either
#39
Originally Posted by slamedham
hey man by chance what harness was it that you used?
is it he GM10B... if so i'm gonan be mad becasue i picked up the GM05B last night...
#40
no accesory in your car..thats really impossible. how would any of your electronics turn on and off with the car? a constant 12v and ground, wont do that job...u need a accesory. im sure u can find something in the car that will do the job. i would help u out but i have all that **** in my car..sunroof,etc. goodluck
#41
Not sure what you would tap in to for an accessory lead if you have a base model without a sunroof......
#42
I just figured that all of them have a roof fuse here from what I've read here -- my car has a sunroof so obviously it has a fuse for it. I'm pretty sure I read on here people who have a base model with no power windows and have a sunroof fuse.
#43
Well, too be honest i havent checked whether or not i have a sunroof fuse, ive been at work at havent had the time today...i will when i get home and if i do than il just wire it there..if not il figure something out....also..im gonna wire in some interior led's, where should i wire em to?
#44
Wipers! Sure you might not have the delay untill the doors open but it will turn off when the car turns off.
#45
That's probably what he has it wired to already. If you tap the wiper fuse, the radio will turn on when the ignition is turned to run (not acc) and will turn off as soon as the car goes off.
#46
fuse tap for 12v accessory power
where can i find a bracket to tap the fuse? ive been to best buy, home depot, lowes, and autozone and none of them have what i need.
EDIT: nvm, i finally found them at radio shack
