xm radio
Old 07-18-2006, 09:48 AM
06COBALTBULE's Avatar
xm radio
I want to keep my stock raido it works great for now my car is brand new only has like 500 miles on it I would like to run a XM radio if anyone has this could you tell me how you ran the wire to go outside on the roof.... Can someone help me other wise I am thinking about taking my stock player out and get a new one
Old 07-18-2006, 09:54 AM
iLLmaTic3s's Avatar
do u have the pioneer setup in your car?
Old 07-18-2006, 07:49 PM
nope its all stock nothing new just plain
Old 07-18-2006, 11:37 PM
iLLmaTic3s's Avatar
personally..i would put a new deck in..once u add a aftermarket deck to your stock speakers ur going to get better sound, then add the XM(dedicated to the deck or plug n play with a hardwire aux to it.) how much r u lookin to spend
Old 07-19-2006, 09:04 AM
i was going to do the xm where its just plug and play right now i am going to be getting a deck from my boy and hes giving me a alpine for pretty much nothing ....
Old 07-19-2006, 09:09 AM
JimmiLS05's Avatar
I'd wait till you got the deck. Instead of having to set your deck to Aux and then tune in with the XM unit. That way you can just get the xm box and plug it into the deck and run everything through there. That'll also save you some $ I think
Old 07-19-2006, 09:12 AM
snobird's Avatar
terk makes a kit where the harness plugs directly into your cobalt factory radio and uses the factory radio to display messages signals stations etc the kit includes everything u need and it plugs direct into the blue harness i bleive in the back of your radio i got mine for $250
Old 07-19-2006, 09:21 AM
JimmiLS05's Avatar
THe kit I got for my xm ready pioneer deck in my last car ran me $100 and I installed it myself, so depends on the route he wants to take
Old 07-19-2006, 09:27 AM
snobird's Avatar
was it aftermarket or factory cause the terk is made for factory radios only and i cant see cause their is some bright ass pink writing on here
Old 07-19-2006, 09:37 AM
blkcobalt's Avatar
I have an aft/mkt XM reciever in my Cobalt. My radio picks up signal from XM reciever via an unused radio station. I don't have any reception or sound issues. My antenna for the XM is ran thru car and mounted to the front edge of the trunk lid (magnetic mount).
Old 07-19-2006, 09:39 AM
snobird's Avatar
blk dont mount the antenna outside u should nount it inside how do you think we get those 5 finger antennas so cheapp j/k i always mount mine inside
Old 07-19-2006, 10:24 AM
blkcobalt's Avatar
I tried mounting the antenna, in the trunk (top of lid), next to factory antenna, and a few other places.......but the reception was not as good. The signal would fade in and out depending were I was at. With the antenna mounted to the outside of trunk lid, I have had no reception problems at all. As far as 5 finger shopping..... Smith and Wesson has my back!
Old 07-19-2006, 11:35 AM
well the only reason i ask is that i am not ready to get rid of my factory deck i want to keep it and my boyfirends parents both got the xm and just wired it to the cigertte lighter and then the antenna outside so do you have to wire it outside or can you keep the antenna inside the car or what so confused on this ....
Old 07-19-2006, 11:42 AM
firesting's Avatar
hey, i know you're confused and so was I before I bought the xm radio. Since I'm at work, I obviously can't post up any pics. But once I get home, i'll explain everything I did and am planning to do with my XM Radio and the way I set it up, which radio I bought and why and how I passed the wires. Also, my opinion about everything with tons of pics.
Old 07-19-2006, 12:28 PM
xtremeGM's Avatar
Thats where I mounted mine, I didnt want the antenna on the top of the car. So its on the trunk hidden behing the spoiler.
Old 07-19-2006, 01:41 PM
JimmiLS05's Avatar
The antenna has to be outside of the car in order to receive the full signal
Old 07-19-2006, 03:32 PM
where did you run the wire to get it under the spoiler thats were i was going to run mine to i need details i am getting mine in about a week for free cant pass up a xm for free..
Old 07-19-2006, 08:04 PM
iLLmaTic3s's Avatar
well its magnetic, so it will stay..u just will have some slack when the trunk opens...zip tie it to a spot in the car in the trunk where it will hold when the trunk is up. yet put it there and remove some of the weather strippin..and feed it uner there and put it back...it shud hold it then zip tie it to something...then run it up to the front of the car where te unit will be. fold the seats down run it down the seats under the plastic for the door and such...put some slck and tie that up and put it by the hood lever. and run it to where ever u have the unit..thats really the easiet way...lol alot of stuff rite there
Old 07-19-2006, 08:52 PM
will you have enough wire for that
Old 07-19-2006, 09:31 PM
JimmiLS05's Avatar
I'm sure you can get an extention kit if you do come short, but you should have enough
Old 07-20-2006, 09:46 AM
iLLmaTic3s's Avatar
yeah u will have enough wire..ive done cars at my job like Escalades and i put it in the back and it always reaches..the wire is pretty long...so ur gonna go w/ a plug n play or that hardwire XM for your factory radio?
Old 07-20-2006, 10:29 AM
I Am Going To Go With Plug And Play Why Is That Bad
Old 07-20-2006, 11:01 AM
iLLmaTic3s's Avatar
no its fine...u can take them in and out of the car...if u want the better sound get the XM FM Direct kit which hardwires it and plugs it up to the antenna lines in the car..when u get this part u need a antenna adapter and rev. antenna adapter.
Old 07-20-2006, 07:26 PM
sweet thanks ....
Old 07-20-2006, 11:11 PM
iLLmaTic3s's Avatar
if u need any help w/ that install..let me know...thats how i did my sirius in my car.just without the antenna outside.
Quick Reply: xm radio
