Jan 2010 FCOTM - Onecoldbizl272
Old 01-13-2010, 09:25 PM
  #76
OneCOLDBIZL272's Avatar
Originally Posted by GTPUSER
Hey, congrats, you finally got COTM, you deserved it!
Thanks man, it was worth the wait.
Old 01-14-2010, 02:07 PM
  #77
Z Speed's Avatar
everyone needs to just stop bickering... Everyone well almost everyone has made resolution with me... Still dont know about eric lol but needless to say it should stop... let it go and let the past be the past... yes derek is my friend but I do also consider all the other guys ive meet friends too.
Old 01-18-2010, 09:27 AM
  #78
joe0016's Avatar
How did u get the front lights?? did u paint them yourself or buy them?
Old 01-18-2010, 10:45 AM
  #79
booSSted23's Avatar
miller park and the art museum, looks good
Old 01-18-2010, 10:47 AM
  #80
I'm too JDM for you
BLAZIN07SS's Avatar
i still see no sleeved block?
Old 01-18-2010, 01:47 PM
  #81
Took them apart and painted them my self
Thanks
Last edited by OneCOLDBIZL272; 01-18-2010 at 01:47 PM. Reason: Automerged Doublepost
Old 01-18-2010, 08:00 PM
  #82
joe0016's Avatar
Thanx, and 5 stars on the SS Bitch is baaaddddd !!!
Thanks
And can u list the steps on how u did the lights like how u told somebody how u did the "evo mod" , I just rly dont want to **** upp.. Like did u need to reapply a sealant to the lights??
Old 01-18-2010, 09:53 PM
  #83
I'm too JDM for you
BLAZIN07SS's Avatar
Old 01-18-2010, 10:32 PM
  #84
Basically what you need to do is buy the paint and one tube of black or clear silicon sealant from an auto store, now I used a gas stove or electric stove. heat it up to about 200 degrees no hotter, let it pre heat and when its ready put the light in the oven, let it sit in there for bout a min. Keep checking it till the sealant around the light is soft enough to push with you finger. Then You will need some type of gloves that can bear a lil heat and also fit tight so you can get a grip, try to pull the light apart if it doesn’t work in the first 1 min of being out put her back in the oven for a min or so and try again, then from there your going to take the few screws out to take the housing off the assembly and paint the headlight how ever you chose to, after it's dry put everything back together. This time use a heat gun on the lenses while the rest of the headlight is in the oven, this way there both parts nice and soft and you can very carefully put them back together, once put together apply some good pressure around the light forcing the two parts back together, either deal with the heat and slightly bear hug it or put it on Capet and push on the lenses for about a min. Put it back in the oven with the lenses facing top and let it sit for about a min and take it out and apply pressure to the light and this time for at least till the sealant is some what hard, should be like 3-5 mims. Use the silicone and go around the edge where the lenses seals and put a small bead around the whole light and go back over it and smooth it out with your finger. That pretty much sums it up it will prob take you an afternoon to do or least few hours. I myself have done about 20-30 sets in the past five yrs I can do a set in bout 1.4hrs start to finish.
i also already answerd you geustion the first time you asked it, i just forgot to qoute it. there are not stock sleeves, the ones in my motor are thicker and dont taper of in thicknees towards the bottom of the sleeve, for i had to get a special tool to remove the stocks ones, it was a pita, maybe your thinking i ment sleeved as in making sleevs so the block is no longer a floating block? that i didn't do, but will be doing something like that when i build my motor even better next time.
Last edited by OneCOLDBIZL272; 01-18-2010 at 10:49 PM. Reason: Automerged Doublepost
Old 01-19-2010, 12:23 PM
  #85
venum_us_2002's Avatar
congrats man, you deserve it
Old 01-19-2010, 05:36 PM
  #86
Thanks Auston
Old 01-19-2010, 08:18 PM
  #87
Maxim_X's Avatar
Did you do any significant lightening to run those times and traps???
Old 01-19-2010, 10:37 PM
  #88
Not really, just about 200lbs. I'm still working on taking weight out the car still, my goal is to shave another 100 off by summer with out lossing creature features, going to be doing lighter rims and tires carbon fiber hood and trunk, and maybe few other things
Old 01-20-2010, 04:28 AM
  #89
Maxim_X's Avatar
I don't see how a 3000lb car can go 12.2@119 with 325whp.
Old 01-20-2010, 08:47 AM
  #90
I'm too JDM for you
BLAZIN07SS's Avatar
glad someone else noticed that
Old 01-20-2010, 03:40 PM
  #91
Max, my car when I bought it back in 6/05, i weighed it on the scale where I use 2 work. With a full tank of gas and the tire in the trunk, I topped the scale off at 2,837 stock.
Updated suspension mods list, will be adding upgraded endlinks sometime in the next few weeks
Old 01-21-2010, 12:06 PM
  #92
Almost postive that was while running race gas, and his race gas numbers were a lot higher than 325
correct me if im wrong Derek
Old 01-21-2010, 06:47 PM
  #93
Maxim_X's Avatar
Even with race fuel you would have to gain 50whp to run that kind of trap and time. Either his mods list is bogus or his timeslip is.
Old 01-21-2010, 07:33 PM
  #94
07cobaltguy's Avatar
Originally Posted by maxim_x
even with race fuel you would have to gain 50whp to run that kind of trap and time. Either his mods list is bogus or his timeslip is.
both
Oh yeah, and derek,I could sure use some extra money right now... since i have to pay in on my state taxes..... Can i have some?............ Considering its part mine anyway, since I and the rest of the hard working wisconsin taxpayers have been supporting your worthless ass, for what a year and a half now. Guess ur build cost too much must be why i have to pay in on my taxes, unemployment dept musta ran low on funds. Wish i could sit home all day, buying things for my car, collecting money that partley comes from My and others incomes, and not making any kind of conscious effort to even find a job... Im proud to work 60+ hours a week for you derek, and barely make my own bills. I wish i could succkle from the teet of the state.
Old 01-22-2010, 12:24 AM
  #95
Umm jumbo I have always been looking for a job sep for the first six months of being unemployed, could I have looked harder?? Yes I could have. cause sandy told me to just stay home and take care of things around the house cause she flet bad cause she was why I lost my job, and no that not me blaming her, I lost my job cause she was in management and they didn't like that was was dating her, and some of the people felt threathed that one day I would of taken their job from them. and my unemployment is being Paied by the job I worked at for six years perviously, that I paid into that was employer ownEd, so it actually has nothing to do with you tax dollars yet. Plus I'm not the only one unemployment has been at a record high. And you have never supported me so don't think you did get off your high horse, my wife supported me, not you. Stop claiming 2 or 3 on your taxes and you wouldn't owe, and I don't want to hear your excuse of why you do that because of what you make an hr. But your intitled to your opinion which is cool but, your really starting to abuse it. I built my car with the the 1,300 that sandy gave me and the money that I have in savings and the 3,500 loan I took out at my bank. I also was bought a few parts from my dad for my bday, back then. Your supposive tax dollare put food I'm mine and sandys mouth. I also have been workIng threw a temp place doing temp jobs, lately, I'm also in the works of try to get grants to go to school for auto body. Sandy knows the job market sucks she's been unemploied since the beginning of nov, she was denied unemployment, so we don't care that you owe money on your taxes, we have our own issues. So stop trying to add to them. Your problems are not my fault. So on another note why would I barrow money to someone who's an, ass hat, and been nothing but a dick to me, I never did anything to you, don't blame me for your problems like you claimed I blamed everyone else for mine. I'm dealing with mine, deal with yours, Once again you can flame me all you want I don't care, it only shows a self reflection of you your self. I've allways been one of those guys that everyone knows but is under the radar. stop cuttering my thread with your bogus crap. By the way brush you ******* teeth kid last time I saw you it looked like you brushed with a tube of peanut butter tooth paste. Your disgusting. "Its not what you have done for me in the past, its what have you done for me lately". That's how I see how you work, I can't or havnt done anything for you guys so screw me right. I have a depression problem that's sure to have been known by some of you yes, I can't help that, but I can get help with learning how to deal with it, which I am, so you want to help the matter because sandy cares about me alot. So if your really half the friend you claim you think are to her leave me alone. Cause she is helping me with my depression. Thank you please just honor that if you have so much as an ounce of respect for her.
Old 01-22-2010, 02:05 AM
  #96
Preston's Avatar
race gas numbers are a secret, grow a pair and post up.
Put up or didn't happen. Simple as that, **** i can say my LS/V will put down 180 to the wheels, but guess what, i dont have a sheet and never hit the rollers. So i am not gonna say what i could put down, or say what i "could" run.
i see no god damn proof for **** in here, besides a bunch of god damn ******* writing.
baha, i can't wait for spring. I will start up my car and say, damn does it feel good to done all the work on my car and not have to sit there and say "what it supposedly does" Or "keep secrets on what it put down"
hell if i owned a car, i would want people to know what it put down instead of having to sit here and say "its a secret"
Jesus ****, these forums suck now.
Old 01-22-2010, 10:10 AM
  #97
vhowse07's Avatar
Rem ind me never to move to WI.. Lol Congrats on COTM
Old 01-22-2010, 10:42 AM
  #98
Lol haha, now your thinking. And thank you very much.
Old 01-22-2010, 01:06 PM
  #99
Preston's Avatar
it isn't bad, just i don't like people who sit here and make claims, after claims about there cars...but show no proof....
and i wouldn't ever shed a damn tear for you. hah
Old 01-22-2010, 02:38 PM
  #100
Ask me again if I care what you think.
I guess it's true what they say, "friends come and go, Enemies accumulate"...
Last edited by OneCOLDBIZL272; 01-23-2010 at 03:24 AM. Reason: Automerged Doublepost
Quick Reply: Jan 2010 FCOTM - Onecoldbizl272
