Forced Induction Turbos/Superchargers
Forced Induction 101
Old 11-15-2005 | 07:07 PM
Nocturn's Avatar
Any example of a lysom supercharger used on a factory car?
Old 11-15-2005 | 07:57 PM
Brian MP5T's Avatar
Mazda Millenia 2000, Miller Cycle Engine...
Whipple Charger
Originally Posted by Whipple Charger
If you’re interested in building your own supercharger packages for kits to sale to the general public, or if you’re building a custom application, there is no better supercharger than a Whipple Twin Screw Compressor. OEM manufactures utilize positive displacement superchargers due to their incredible throttle response and drive-ability of a big cubic inch motor. When building a system for the consumers, you must provide a very broad power band with a high peak horsepower level, only the screw compressor can give you this. This is due to the high adiabatic (up to 80%) and volumetric efficiency levels (up to 98%). The Eaton/Lysholm screw compressors are the most reliable, dependable, performance-enhancing item ever designed for either low boost or high boost levels.
The screw compressor is by far the best supercharger available today; it’s the only supercharger to provide a positive displacement design for maximum low-end torque as well as high efficiency for maximum top-end horsepower. No other supercharger in the world can offer the same unique benefits. Centrifugals and turbos have tremendous lag time during shift points, on-off throttle and off the line boost. Roots-type superchargers have been proven to not be very efficient, especially at higher boost levels. Whipple Superchargers has a variety of screw compressors for all types of applications, anywhere from a 1.2 Liter compressor to the 3.3 Liter compressor. Whipple also has a wide assortment of drive lengths, pulley combinations and bypass valves for all types of applications.
Old 11-15-2005 | 08:00 PM
Brian MP5T's Avatar
Here is what it looks like...
It's going on the Porsche 944...
Old 11-15-2005 | 08:26 PM
OniMirage's Avatar
very very very nice read ... after reading that twin charge setup it almost seems like you would be prolonging the cars life by running at an almost always lower inlet temperature ... no? to top it all off our cars have an intercooler so having said that wouldn't the end result be an even cooler 20psi to the engine? (well using the example it would be 19 psi after hitting the supercharger intercooler ...no?)
Old 11-15-2005 | 08:38 PM
Brian MP5T's Avatar
Remember two things...
1. Can your engine Handle 20 Psi... Never unless you build it
2. Is it worth all the extra weight and the pulley or could you do the same thing with one big turbo...
It's a very cool idea for a showcar but even though it proves to be impressive at making HP, it's very complicated when compared to just a S/C or just a Turbo.
The parasidic drain of spinning the S/C is a bit of a negative plus the additional weight of all that **** is just too much.
Can we agree that in reality, if the same car was simply turboed at one Psi more than the Turbo/Super and the intercooler was made a bit bigger to compensate for the heat, it would be a better performer.
My point is this, if it was that good, we would all be doing it.. NO?
Believe me, I am not "Poo Pooing" the idea, it's wonderful to think way outside the box sometimes...
Old 11-15-2005 | 08:59 PM
OniMirage's Avatar
it means that your normal ^^
Old 11-15-2005 | 09:37 PM
Brian MP5T's Avatar
Roger That!
Old 11-16-2005 | 03:09 PM
Brian MP5T's Avatar
Ok, So Updated
Intercooler
https://www.cobaltss.net/forums/show...6&postcount=12
Alcohol Injection
https://www.cobaltss.net/forums/show...6&postcount=13
Peace...
Old 11-16-2005 | 03:29 PM
OniMirage's Avatar
wait now im lost at this intercooler deal ... the air to water intercooler that the ss uses ... does that mean that there are two intercoolers??? wasn't there a video that showed how the super charger works and in the video wasn't it an example of the inter ... inter cooler? does that mean we have two? sorry im feeling really retarded with so much info flying around ... where am I?
Old 11-16-2005 | 03:46 PM
R33P3R007's Avatar
360 L337 User
your in arizona. But Brian is a machanical genius. he is just a plethera of information. And is a huge asset to the site with about 150 posts in his 2 days. If my head didn;t hurt from all this knowledge I would try and help...... Sorry
Old 11-16-2005 | 03:52 PM
  #36
Brian MP5T's Avatar
Only One. It is more compact and easier because you don't have to move the air to the front of the car, just Hot Coolant...
Originally Posted by motorportal.com
A compact Eaton M62 Roots-type positive displacement supercharger is used because of its immediate response traits – there’s no “lag” when more power is called up by the driver. It makes a maximum of 12 psi of boost and is bolstered by an air-to-water intercooler. The intercooler cools the heated air charge before it reaches the engine, increasing the density of air to increase power and reducing the propensity of detonation at high rpm and high boost levels.
There...
Old 11-16-2005 | 04:17 PM
  #37
GTPsRule's Avatar
There is one intercooler mounted in the intake manifold under the blower that the compressed air flows through. The coolant that is pumped through the IC is sent to nothing more than a radiator to the front of the vehicle, not a seperate IC. So its more like the SS has one intercooler and two radiators
Old 11-16-2005 | 04:26 PM
  #38
OniMirage's Avatar
ahhhhhhhhh so the effect is more cooling than one or the other by itself?
Old 11-16-2005 | 04:51 PM
  #39
06black's Avatar
best ever
WOW brian AMAZEING! thats the best write up on this site! i've learned a bit as well....good job man mayjor credit to you on takeing the time to do that....i hope everybody has to read that before that can join the site to keep the total morons outta here! GOOD JOB!
Old 11-16-2005 | 04:53 PM
  #40
Brian MP5T's Avatar
Thanks for reading it...
Old 11-16-2005 | 05:01 PM
  #41
GTPsRule's Avatar
Now for the big question here: Did you actually write all of that all by yourself? Or is this just a good copy and paste job?
Old 11-16-2005 | 06:09 PM
  #42
Brian MP5T's Avatar
I'm a mod on several forums and I have been working on that series for a year or so here and there. If it wasn't me, then I quoted it...
Old 11-16-2005 | 06:20 PM
  #43
wasey'sghost's Avatar
Know what would be really cool... if everything in it was fact based, instead of having blanks (things you know nothing about) filled in with oppionions, your's or whomever's. Besides that pretty good write up.
Old 11-17-2005 | 09:26 AM
  #44
Brian MP5T's Avatar
Nice, It Seems that you are Banned...
Already... One hit Wonder...
Old 11-17-2005 | 06:58 PM
  #45
Brian MP5T's Avatar
http://www.dipmec.unian.it/disegno/d...ompressore.avi
Here is a link for a Video of a Lysholm Supercharger
Old 11-17-2005 | 07:01 PM
  #46
Brian MP5T's Avatar
http://www.dipmec.unian.it/disegno/d...olumetrico.avi
Here is a link for a Video of a Roots Blower.
Old 11-17-2005 | 07:07 PM
  #47
Brian MP5T's Avatar
Here is a link for a Video of a Turbo.
Old 11-17-2005 | 07:22 PM
  #48
Brian MP5T's Avatar
http://www.rotrex.eu.com/
ROTREX SUPAECHARGER
New New New Shizzy..
Here is what I could get...
Traction transmissions require relatively large engagement forces between traction surfaces to prevent slippage. The ROTREX automatically adjusts the contact force, to optimize the gear for the current torque required for the situation and application at hand. This means a reduction in frictional losses and wear of the transmission. Where full torque is transmitted, the transmission has the capability to provide sufficient traction force to prevent slippage.
Characteristics
· No high speed bearings needed
· Based on standard components
· Power transmission by traction engagement
· No noisy toothed gears
· Robust and durable by design
The Rotrex patent may be applied to gear-designs in various ways.
For automotive applications three gear-families are currently manufactured:
Old 11-19-2005 | 10:04 PM
  #49
wasey13's Avatar
Why don't you look up some more facts about the stuff you have no idea about? Like my ghost made mention of.
Originally Posted by BrianMP5T
A Centerfugal Supercharger combines the negaitve qualities of both a Turbo and a Supercharger. They are the least capable at making good boost pressure but are effecient at low pressure applications. They make heat like a turbo but Rob Horsepower like a supercharger. So that makes them...Moderately desireable for big horsepower. More for minor power adding.
HAHAHAHHAHAHA This is one of the funniest things ever said on this board. Do some research... start here procharger.com.
Old 11-19-2005 | 10:50 PM
  #50
DeuceDeuce41's Avatar
