Forced Induction Turbos/Superchargers
Time to turbo the cobalt!
Old 03-16-2011 | 08:37 PM
terry11's Avatar
Originally Posted by jmarks
A lot of people either hate or love the profec. I have had pretty great results with it on the cavalier. Although, be prepared to spend a few hours dialing it in. Once you get it set up it is really nice. It also have a Hi and Low setting for boost as well, with separate settings for both.
I guess the only thing i'm not understanding is the difference in running this one vs. the typical mbc. What does the electronic system do differently? I'm guessing just limits the amount of pressure in the vacuum line going to the gate so it doesn't start opening early?
Old 03-16-2011 | 11:45 PM
jmarks's Avatar
Its fully programable. A mbc only modifies the signal coming to the wastegate. You program when you want the wastegate to open with the profec. There is a seleniod that controls what pressures the wastegate sees and when.
Old 03-17-2011 | 12:33 AM
jmarks's Avatar
Finished welding most of the exhaust, still need to weld the hangers on for the muffer and the tip but that should happen tomorrow. Hope to be driving it as well!!
After I get it dyno'd I will be taking the exhaust off and coating it with a techline coating. Worked well on the cav so we shall see how it works on the whole exhaust!! Almost there!!
My welder is starting to take a ****, so I will be upgrading soon hopefully!
Old 04-25-2011 | 02:50 AM
jmarks's Avatar
A little up date.
Car has been running well for a couple months. I have been tuning the lower rpms and getting the thing driveable. I hate running around in the silverado getting 14 mpg. I am getting around 30mpg with city/highway mix so I am excited to see what I get when it warms up and I get it on the dyno.
Currently I have the boost controller set to 18 psi. It is super rich up top. I would mess around with it but I will let my tuner take care of it for me. I am hoping I can hit 325-350 on the rollers sometime next month.
I ordered a hahn intake mani and that should be coming soon. So I will have more pics once that happens.
I have decided I am going to do an f23 swap with an obx lsd (say what you want but my cav runs one and has 474 hp so its working). I have 2 brand new f23s and a new gear set from another. I picked up a clutch master stg 4 clutch as well. So once the clutch starts to go I will get the lsd and get the trans buttoned up and start the swap.
Now that its warmer I will try and get an exhaust vid.
Old 04-25-2011 | 10:50 AM
xmusic_addictx's Avatar
Sounds like its working pretty good, good work!. I dont think youll have a problem hitting those goals at all. F the haters, and let me know how that LSD is lol The same one I was looking at..
Cant to to hear the vid!
Old 04-25-2011 | 05:51 PM
jmarks's Avatar
It works very well in the cav. It needs a little modification before it can be dropped in the trans but everything we have seen says it should do pretty well. There is also a guy running it with 551 whp and some pretty big slicks and he has had pretty good luck with it.
I just cant justify spending 2k + on the f35 to "maybe" see if it will work.
Old 04-26-2011 | 12:04 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Kennyspec did an F23 swap on his SS/SC... you can probably PM him to get some details on what needs done.
Old 04-26-2011 | 12:35 AM
jmarks's Avatar
I have talked with him a few times.
I may do a write up on the f23 swap and the obx lsd install.
Old 04-26-2011 | 12:37 AM
Sub'd for this lol
Old 04-26-2011 | 12:43 AM
BumbleBee's Avatar
get some vids please.
Old 05-11-2011 | 01:42 AM
  #36
jmarks's Avatar
Hoping to get this on Friday!!
Old 05-11-2011 | 05:05 PM
  #37
Meh, Hahn. I've seen them having a lot of problem with cracking welds.
Old 05-11-2011 | 06:00 PM
  #38
ebristol's Avatar
I'll subscribe to this.
Old 05-11-2011 | 06:05 PM
  #39
Chevycobaltss3's Avatar
yeah i will vouche for the welds cracking. i tuned a dude with the hahn intake and his maf trims were going lean to rich and idle was ****. after inspecting the intake, there was holes along the top of the intake on the weld...... just be carful.
Old 05-12-2011 | 12:35 AM
  #40
jmarks's Avatar
We shall see. If it cracks I will have my welder weld it up. I was going to have the guy that built the intake for my cavalier fab one for me but that would have been $700. I got this for $450 shipped from hahn so we will see.
Old 05-12-2011 | 12:53 AM
  #41
jonathan923's Avatar
nice build there sir looking very good.
Old 05-14-2011 | 08:42 AM
  #42
jmarks's Avatar
All installed ready for the dyno!
Coming this summer to a city near you.... Ready for some dyno destruction!
Yes the balt needs lowered....ALOT
Old 05-14-2011 | 09:36 AM
  #43
06_cobalt's Avatar
I like! Can't wait to see results.
Old 05-14-2011 | 08:42 PM
  #44
I like your garage lol
Old 06-12-2011 | 10:38 PM
  #45
jmarks's Avatar
Went to the dyno Saturday. Here are the results!
Working on getting a vid up.
This was on 17psi
Old 06-12-2011 | 11:03 PM
  #46
BumbleBee's Avatar
Very cool man,good numbers.
Old 06-13-2011 | 12:40 AM
  #47
terry11's Avatar
Awesome job so far!
Old 06-13-2011 | 06:17 PM
  #48
I would look into those dips and rises a little bit more. Probably just need to smooth out the MAF or something. Hard to say from here. How much timing are you running past 4500?
Old 06-14-2011 | 12:23 AM
  #49
imphat0260's Avatar
18*.... and please keep in mind there is no smoothing/correction factor. Most dyno plots you see are smoothed out and corrected to make the graph look smoother. I am thinking this was minor clutch slip as I had the dyno loaded pretty hard. Fueling was **** on, and no KR.. Its the stock clutch with over 100K... The owner(John) did not want to push it any harder or I would have raised the boost and kept going!
Old 06-14-2011 | 02:20 AM
  #50
I dunno... they're wierd. Looks like they happen almost every 200 or so RPM... and they last about 200rpm too. Very odd.
