Forced Induction Turbos/Superchargers
turboing the 2.4..some quick questions
Old 08-06-2008 | 09:17 PM
ssbalt06's Avatar
1) Where is the best place to find pre-fitted intercooler piping (hahns? i looked and didnt see anything
2) if i am going with a mani with a t28/t28 flange what turbo would be the most bang for the buck? (i would love to get the gt2860rs but its alittle pricy)
3) intercooler.... what size should i go with, best suitable? (thought about going with an srt front mount...)
4) what injectors are appropriate for the 2.4 and turboing? could i go through hahn also for that? maybe do some 60lb'ers?
thanks guys. please let me in on any info. once again thanks again
Old 08-07-2008 | 10:05 AM
celicacobalt's Avatar
1. Talk to garrett and see if they will sell you just the piping.
2. gt2860rs is ok for under 300whp but i cant get mine to boost more than 11psi. look for something bigger if you want big power.
3. srt front mount is good for bigger power but if you plan to stay under 300whp then smaller would be better for efficiency.
4. 60's are the way to go. i bought mine from hahn racecraft as direct drop ins.
Old 08-07-2008 | 11:22 AM
mike25's Avatar
not to mention if you go with an srt4 front mount youl have to cut the bumper
Old 08-07-2008 | 11:59 AM
TheSilentFart's Avatar
I'd stay away from the GT2860RS. I really feel that it's undersized for this motor. We ran the numbers and it just seems way too small.
I was going to go with a GT2871R, which is pretty good for the 2.4L motor. I ended up getting talked into something a little bit larger, but that's because I plan on pushing more power later with a built motor/trans.
As far as IC piping, the Hahn stuff is just the Garrett Kit piping. It's a recirculating BOV setup in 2" piping IIRC. I'd suggest either having a shop fabricate it, or buy a generic kit and piece it together with silicone couplers.
Old 08-07-2008 | 04:49 PM
ssbalt06's Avatar
what are the prices for the gt2871r?
and i did thnk about that whole thing with the generic intercooler piping kit
Old 08-07-2008 | 05:09 PM
djt81185's Avatar
What type of boost controller do u have and what is it set at?
Old 08-08-2008 | 09:38 AM
I dont have a boost controller at all. just have the wastegate rod fully turned out so as to not hold any boost back and all it will give is 11 psi.
Old 08-08-2008 | 09:41 AM
06black's Avatar
you have a boost leak then!
what kinda janky wastegate do you have?
to the op, you need a larger piece then some t28 turd like your manifold will force you to use.
Old 08-08-2008 | 11:13 AM
djt81185's Avatar
No boost controller is why you arent getting more then 11 psi...your just running off the wastegate spring. Hell you might even get better boost response with a boost controller since it will keep the spring from cracking too early. Tuning boost off a wastegate spring only is so mid 1980s.
Old 08-08-2008 | 11:18 AM
PpAzZ1101's Avatar
Really... a boost controller isn't that expensive if you get a cheapo from ebay. A really nice manual one should run you $90 new, maybe $60 used if you can find it. I recommend the Forge Unos.
Old 08-08-2008 | 11:52 AM
06black's Avatar
dan-dan
re-read what he said...
something along the line of a gate rod (huh?) but he says hes got it set and "all it will give is 11 psi"
so unless i'm reading his poor grammar incorrectly, it sounds as if hes got a massive leak....but i've never seen a WG with a rod on it.....
Old 08-08-2008 | 01:44 PM
PpAzZ1101's Avatar
Internal gate on his GT2860RS.
Old 08-08-2008 | 02:46 PM
djt81185's Avatar
dan-dan
Like Paz said its an internal gated 2860rs...internal gates have rods as the actuator isnt directly on the valve but relocated somewhere else
Old 08-08-2008 | 02:47 PM
PpAzZ1101's Avatar
Wastegate actuator with "rod":
Old 08-08-2008 | 09:11 PM
I tried finding this out before and i couldnt get an answer. i wasnt sure if a boost controller would do something other than turning the wastegate would. I guess later on when I have $, i might try to throw a BC on and retune for more power. I just gotta watch the tq because I don't have $ to rebuild the trans anytime soon.
car has been fully checked over for boost leaks and there is none.
Last edited by celicacobalt; 08-08-2008 at 09:11 PM. Reason: Automerged Doublepost
Old 08-09-2008 | 12:52 AM
mike25's Avatar
i picked up a mbc for about 60 off ebay...i forget the name of it...hallman maybe? anyways i was planning on just running off the wastegate for my setup for now...but then again i have an external gate
Supercharged06SS
12-11-2022 05:47 PM
05-28-2022 04:47 AM
brandon04
10-21-2015 08:04 AM
patooyee
10-15-2015 06:11 PM
maliki778
10-01-2015 08:39 PM
Quick Reply: turboing the 2.4..some quick questions
