2007 cobalt downpipe
Old 09-18-2016 | 03:25 PM
Ss or str's Avatar
Hey guys I have a 3" megnaflow cat back I want it loud where is the best place to buy a catless downpipe for my car? I found lots of place but it is just for 08-10 tc I have 07 sc
Old 09-18-2016 | 03:29 PM
cluelessk's Avatar
This information is readily available.
I've got a catless TurboXS DP I bought second hand.
Old 09-18-2016 | 09:25 PM
DarrenWS6's Avatar
There are plenty of options, given the Magnaflow kit is designed to bolt up to stock, it should fit the 2.5" ZZP quite fine.
Ecotec Parts 2.5 inch Stainless Cobalt/Ion Downpipe
Old 09-18-2016 | 10:19 PM
Ss or str's Avatar
I have a 3" cat back exhaust would it fit since this down pipe is 2.5"?
Old 09-19-2016 | 01:04 PM
jmix's Avatar
That same company that was linked to you sells a 3" downpipe as well.
Old 09-19-2016 | 03:03 PM
Staged07SS's Avatar
Administrator
Administrator
You would need a 3" downpipe.
I had ZZP's 3" downpipe on my SS/SC.
I honestly wouldn't run a catless exhaust unless you have a Corsa catback which has the RCS resonator. I've heard catless SS/SC's and they sound like poop.... Very raspy and hollow sounding.
Old 09-19-2016 | 03:05 PM
DarrenWS6's Avatar
Most catbacks, regardless of catback diameter size, are designed to connect to the factory parts. I am almost sure it will bolt up to the OE size 2.5". If you can get under the car and look at the connection joint ( and measure ) I would see what your best answer is. You can get the 3" downpipe and make it work as well. Give ZZP a call and see what they suggest.
Old 09-19-2016 | 03:26 PM
Staged07SS's Avatar
Administrator
Administrator
The O.E. SS/SC downpipe is 2.75" with a small 2.5" portion at the outlet. If the OP has a 3" catback he will need a full 3" downpipe. Most 3" catbacks have a 3" inlet flange.
A 2.5" downpipe or even the stock downpipe won't bolt to that. It is also silly to bolt a 2.5" downpipe to a 3" catback.
If it was the other way around it would make sense... 3" downpipe to 2.5" catback.
Get the 3" downpipe and be done with it... I'd never recommend a 2.5" downpipe on an SS/SC unless you plan on staying basically stock or no more than S2.
AngelTiger82
18
09-16-2016 08:02 PM
harold_9549
09-15-2016 03:12 PM
BluebaltSC
09-15-2016 07:32 AM
Hambone
09-14-2016 12:24 AM
Quick Reply: 2007 cobalt downpipe
