60,000 mile tune up
Staged, the NGK's were in the SC right? hes got the 2.4. maybe im wrong.
I've always put in whats came out. im fully bolted, no tune, but the car runs great with the delco plugs. as said above fuel filter, any will be fine as long as it for your car.
trans fluid. wont ever hurt to change it early, GM recommends 100K.
for a coolant flush, ive alwasy pulled the hoses off, stuck a garden hose in the lower hose and let the car pump fresh water through itself for a little bit, then drain it down and addd straight Dex-Cool. my hydrometer reads really close to 50% when ive done it this way. make sure you get a good 50/50 mix in there.
The stock plugs will say AC Delco on them.
The SS/SC's stock plugs have an AC Delco part number & NGK part number.
Your heat range is prob a 5 versus the SS/SC's stock heat range of a 6.
My owners manual has the spark plug part number for all the Cobalts 2.2, 2.4, 2.0.
Also, the fuel filter part number is in there as well.
Yep, I know he has a 2.4.
#36
just took a look in the manual and it calls for iridium plugs? i could have sworn that i saw platnum tip on here. and there was nothing about the fuel filter
#37
^^^ This, AC Delco makes an irridium plug that is like $7 each and you can get this at adv. auto parts. Ran them in my 90k mile '06 SS LE5 and they were awesome!
If you go to a shop, like a quick lube, they usually have a machine which will disconnect one of your radiator hoses and hook one end to the machine and the other to the machine at a different location. They then will use the machine to flush water and/or new fluid through your system til it comes out looking new. (usually 15-20 qts depends on how dirty is what we used to run when I worked at the local Pennzoil)
This is very good to know!
In my '06, I never flushed the Tranny and at about 90k miles it started giving me alot of issues (slipping and such)... Some people say 50k miles and some say 100k but I would flush it every 50k to be safe and do filter every 100k. (I was going to do the fluid and filter but I ended up trading the car in at 98k miles for a '10 LNF)
Fuel filter - I personally had just bought a Duralast from Autozone, worked fine, no complaints.
My swar bar endlinks also went out at 70k miles and it fairly common on those cars. Wouldn't be a bad idea to buy some used FE5 end links or hit up ZZP or someone for some Moog's.
My .02
My .02
#38
Just go to oriellys and tell them what you need. Give them the year and trim of your car and they enter it in the computer and tells the them what is for your car. That's what I did.
#39
My .02
My .02
and how difficult is it to change the trans fluid and filter.
#40
Typically the tranny fluid and filter isn't a big deal to do yourself, just messy. However I personally would have taken my car to the dealership or a shop to have done because there is no tranny dip stick like on a grand prix, silvarado, camaro, etc etc. There is just a fill hole/plug. I would not be comfortable guessing as to how much fluid is in there or how much to put in. I figure if the dealership messes that part up and something happens, I can go back to them. If I mess it up, well then im eff'd lol
#42
my neighbor owns a shop i get all my work done there and im sure hes done tranny fluid before so ill bring it up to him
