? about Cobalts Ignition
My friend told me that on her 2005 Cobalt LS she cant start her car up and then just pull the key out of the ignition(while engine is still running), get out of the car with keys in hand(while engine and all electronics are still working) go and do whatever and come back get in the car put the key back in the ignition and then drive off. I dont see how thats possible i tried it on mine and i could not do it. So my ? is, Is there something wrong with her car that she can do this or do the other LS balts do this to?
Ok thats what i thought but she tried to make me think it was some kind of extra feature like remote start or something. Yeah see cant her warrant is up. She has around 45,000 miles on it.
so .. go fix it.. its not expensive.. local part starts tend to sell ignition switches from like 10 - 30$
if no.. then just hook her up a remote start/push button
Last edited by Acidangel_5.0; 05-04-2007 at 10:30 AM. Reason: Automerged Doublepost
The igition cylinder or just the tumblers in the cylinder is what's bad. It happens a lot with the Grand Ams and Malibu's. They will probably have to remove your ignition asm. and either replace or recode your cylinder.
If you tell a dealer your ignition switch is bad they are going to look at the electrical part of your ignition and not the part your key goes in.
This is all factory settings. An aftermarket may be different or do what is happening to hers.
she might need her shifter replace because that happen to me b4ore..i had to replace the whole shifter..because my key wont come out i have to slame my shifter to park serval times to get it out
Well i was at her house the other day and took it for a ride. I backed the car out of a parking spot and while the car was still running and i was in Reverse i could pull the key straight out of the ignition(while in the run position), and everything stayed running. I could even drive it while the key sat in the cup holder. Then when i went to shut it off i just put the key back in the ingnition and turned it off.
satisfied
10-19-2015 01:35 AM
