about the gas
Yes sir you do! Running 87 or 89 may cause some pinging or knock which will cause the PCM to reduce timing and that will affect your power. Your car may drive fine but you will more than likely have reduced power.
Mike
Mike
or it could damage a piston... which you would replace= way more money than the added cost of gas... someone did a little research around here and figured it only costs about $160 a year more to put premium in instead of regular
roth
09-26-2015 12:16 PM
