AEM failsafe boost & Wideband gauge
Old 12-08-2015 | 03:24 AM
Sl0wbaltSS's Avatar
Is it worth it? Since I have a sedan and zzp only offer's 2 gauge pod I can fit one of these and a aero force gauge in it. Does anyone know if it can be programmed to read e85 stoich?
Old 12-08-2015 | 05:04 AM
robertmichaels's Avatar
in for info
Old 12-08-2015 | 09:19 AM
Omiotek's Avatar
They arent worth it in an lnf. For them to work properly you need aems boost control solenoid as well. Plus theres a ton of wiring to do. Its not for your average person to wire up.
Old 12-08-2015 | 01:39 PM
Sl0wbaltSS's Avatar
You can just tap into the line coming off from the manifold? What about killing the ECU in the event of a setting you have to turn off the ecu?
Old 12-08-2015 | 01:42 PM
Omiotek's Avatar
You cant tap into just the manifold
It wont work. You need their solenoid.
Your ecu is a boost controller, and a very good one at that.
315SS
04-18-2016 10:44 AM
Sachemhockey44
12-14-2015 04:02 PM
dennis69
12-12-2015 07:09 PM
Staged07SS
ZZ Performance
22
12-09-2015 08:48 AM
06SS Browns Fan
12-08-2015 10:38 PM
Quick Reply: AEM failsafe boost & Wideband gauge
