Aem Wideband Help...
ok i had my wideband installed yesterday and i think somethings wrong with the gauge casue all it does is jump around...and before you ask its not the tune cause its the stage 2...at idle it jumps from 13sumthing to 15sumthing and the samething when i'm cruising??? any ideas i bought the gauge new
what he said...it should move around during driving,if it doesnt then its actually bad,but at idle 14.4-15.5 is where u want to be at..and WOT 11.2-11.5,but since ur s2 tune,ur gonna see under 11.2 due to tune being rich
you do know how a wideband works rite???
its going to ocoilate at anything under full WOT and even then it'll jump aorund a bit as your AFR changes with engine RPM
i dont know, i might be going out on a limb here. BUT when you installed the gauge did you install the wide band O2 sensor as well?
if all you did was hook an AFR gauge up to your factory O2 then its going to give you an LED "light show" so to speak.
n20saturn
09-30-2015 12:26 AM
