another Interceptor gauge question
Ok, I am going to buy a Interceptor scan gauge. My guestion is (maybe myoshizawa819 can tell me) will it read oil pressure? I am going to guess no, but if it will I will probably buy two.
thanks,
Dennis
thanks,
Dennis
Straight from Intense's website...
RPM
MPH
Intake Air Temperature
Mass Air Flow Sensor Frequency
Mass Air Flow Sensor (lb/min.)
Engine Coolant Temperature
Injector Pulse Width (bank 1 and 2 if supported)
Long Term Fuel Trim (bank 1 and 2 if supported)
Short Term Fuel Trim (bank 1 and 2 if supported)
O2 Sensor Voltage (bank 1 and 2 if supported)
Manifold Pressure in PSI (Boost pressure for factory turbo/supercharger applications)
Ignition Advance
Knock Retard
Engine Run Time
Battery Voltage
Transmission Temperature
Idle air Control Counts
Throttle Position Percentage
Throttle Position Voltage
Engine Load
Oil pressure (some 8 cylinder engines)
RPM
MPH
Ignition Advance
Knock Retard
Engine Run Time
Battery Voltage
Engine Load
