Can't open door....
Can't open door....
06 SS/SC....
the driver side door will not open from inside or outside whether I use the button lock or use the actual key
it has something to do with the locking mechanism
it started the other day.... drove to work and got out of the car and went to shut the door and it just bounced off the frame, it wouldn't latch shut.... I hit the unlock/lock buttons on the key fob and then it shut.... but then when I went to leave work the door wouldn't open... I had to crawl in through the passenger side....
i got home and alternated pressing the unlock/lock buttons on the door handle and after a couple times I heard the locking mechanism activate and then the door opened.... then it was fine for a couple times....
but now its not opening no matter how many times I do it....
The little lock knob thing by the window goes up and down perfectly fine.... but the locking mechanism isn't catching for whatever reason
When you pull on the door handle from either side... you know how you normally pull it a little bit and then it catches and then you pull the rest of the way and it opens..... now it's not catching the handle is just coming all the way out without catching
Same problem in two cars temp fix
06 SS/SC....
double clutch
01-30-2013 04:22 PM
