The Cobalt is done!!!
Old 09-28-2007, 12:39 PM
SSdan's Avatar
Originally Posted by LE5CAV
By His Slips It Looks To Me Like His Clutch Is Acually Starting To Clip At The Higher Rpms, Are You Driving It To The Track? How Hard Do You Drive It Before You Race? What Rpm Are You Shifting At?
Clutch should have a harder time in the beginning.
Old 09-28-2007, 12:52 PM
Rattlesnake Race Shop
USMCFieldMP's Avatar
Sounds a lot like my car... it just doesn't perform at the track. Icing the S/C is cool and all... but it's your coolant that gets those IAT's down. What you need to do is run the A/C on full blast when you aren't racing. Make a pass... as soon as you are down the 1/4... turn on the A/C (Coldest Setting/Highest Fan)... When you go to park your car... let it sit and idle for a while. In the staging lanes, leave it running with the A/C on... don't turn off the A/C until after the burn out when you are getting ready to take off.
What the A/C will do is activate the fans, which will chill your Coolant out. Helped me out a lot.
Old 09-28-2007, 12:57 PM
07cobaltss's Avatar
Originally Posted by GordyD
60' 2.121
330 6.186
1/8 9.895 at 74.06 mph
1000' 12.750
1/4 15.131 at 95.24 mph
This was at Atlanta Dragway in Commerce Georgia
dude thats a pretty bitch'n 60' time
Old 09-28-2007, 01:03 PM
BlueSS-supercharged's Avatar
carefull tho, this dude at gateway was running his AC and got bitched at because of the water it was leavin on the track
Old 09-28-2007, 01:04 PM
rallyracer's Avatar
There is more to racing that just a damn 1/4mile, alot of cars can run the 1/4 fast but suck ass from a roll or on the twisties.
I love my car.
Old 09-28-2007, 01:52 PM
EthensCobalt's Avatar
wow if i could only get 2.1 60' all the time
do like me wait untill theres a good tail wind use racing fuel and empty everything out the car (btw car ran terrible for a few weeks afterwards) and run a 13.8 @ 103 mph with a 2.2 60'
Old 09-28-2007, 01:59 PM
R&C_rallySS's Avatar
That is the worst advice I have heard in a long time. I'm not trying to be rude but running the AC will do nothing but make the car have to work harder. Its working to cool of the car in the inside. If anything its best to shut off all lights, all air flow into the car. Trust me, I did not trap 100mph stock because I don't know about drag racing. When temps start to rise turn off the car in the staging lane. Pop that hood and let it cool off. It would be much better to set up a switch in the car to turn on the fan.
Old 09-28-2007, 02:10 PM
ItalianJoe1's Avatar
I know it sounds silly, but have you tried disabling the boost bypass valve? I've felt stock SS/SCs lose power for the last few hundred rpms because the car starts to bleed off excess boost. That could give you the symptoms you are seeing, and I have seen it to be random, not all cars do it with just an intake, but I've seen it happen to a stock car with air-box mod only. Just somethign to check.
Old 09-28-2007, 02:14 PM
^ That is a good idea. Mine never showed symptoms of this but some cars do in fact act this way. He may even see full boost quicker. In the case of my LSJ I always seen full boost right as I stepped on it in first gear. Never had a problem hitting 12.5 psi in all gears in stock form. Now I hit around 16.5psi on stage II pulley.
Old 09-28-2007, 03:50 PM
an0malous's Avatar
oh god please dont sit in the staging lanes with the car running.
sitting there regardless if the fans are on or not will have the engine heatsoaked by the time its your turn.
and yeah, water dripping on the track will get you an ass kicking at any decent track.
run the A/C on the way back to the staging lanes, and when you get there shut the car off.
dont start the car every 2 minutes to move 10 feet. get out and push it.
the best thing to do is the IC/FAN relay bypass mod,
so that your IC pump and fans are on with the car OFF in the staging lanes.
Old 09-28-2007, 04:01 PM
  #36
campo165's Avatar
He is absolutely correct, though. It ABSOLUTELY cools the engine. how? i do not know, some secondary fans kick in somewhere. The car will go from 214 degrees to 183 degrees in 2 minutes. It will keep your engine at 183 when you sit in traffic. sit in traffic and look at your coolant temp rise past 220. this car heats up pretty high without that a/c on! Try it. Opening the hood doesnt do that much, in my opinion.
Old 09-28-2007, 05:28 PM
  #37
suprchged's Avatar
IMO dont let your lack of drag racing exerience cause you to trade you will probably regret trucks are turds.
Old 09-28-2007, 05:38 PM
  #38
Grimlakin's Avatar
The reason turning the AC on cools the motor is because the default setting for the motor fan with the AC on is ON.
Old 09-28-2007, 05:42 PM
  #39
XM15's Avatar
Would turning the heat on do the same thing?
Old 09-28-2007, 06:00 PM
  #40
redSSBalt's Avatar
Turning the heat on does take heat away from the motor. That's why when your car is starting to over heart, you are supposed to turn the heat on with the fan at the highest setting.
Old 09-29-2007, 03:54 AM
  #41
r0k0's Avatar
mine completely stock at a shitty track.. i make 14.75.. @ 99mph..
i still have the pirelli's on it and the stock airbox nothing.. now i have the aem filter installed.. and i'm missing my Ingalls engine damper..
but at a good track stock i might just made low 14's
Old 09-29-2007, 04:15 AM
  #42
o3nisoaso3's Avatar
i was about to say turn on the heat... it always drops my coolant temps and i did it at the track but i was at 120 when i started up to move towards the starting line and back at 188 when i was gettin ready to stage so if u can get quickly from ooling off to staged then u should be better with around 150-160ish maybe. idk if thatll help ur prob but it may be worth a try since im not the only one to say something about it
Superslowbaltt
09-22-2015 10:24 AM
Rayray2781@gmail.com
09-20-2015 01:52 PM
Bluelightning
09-08-2015 05:18 PM
jthwjde
09-07-2015 09:24 AM
Quick Reply: The Cobalt is done!!!
