Cobalt trans stuff I guess
hey there
i got a 2010 SS turbo on a tune. trans gave out, input shaft seems to do that rattle thing where it stops when the clutch is pressed, along with SOMETIMES shifting
tbh would it be easier to have it rebuilt. or find a used trans to put in.
oh shoot really lmao I've heard otherwise. Are there things i should check to verify it isn't the trans? To save me from pulling it
It's the aftermarket clutch. Mine didn't rattle with the factory clutch but as soon as I went aftermarket I get a lil bit of rattle. The not shifting sometimes could be either the clutch dragging due to hydraulic issue or the clutch is actually falling apart like my clutchmasters did... twice. If the clutch engagement point is right off the floor and there's good pressure, I would look at the clutch before the trans. The third time I replaced my clutch I went with southbend stage 4 because that's what the gentleman from zzp recommended with my upgrades. He also said the reason why my clutch kept breaking was probably due to boost spikes from the twin scroll turbo constantly stressing it at lower rpm. This clutch has slight rattle/chatter but oh well. Also if you didn't measure the act clutch installed height you may have needed a throwout bearing spacer and that's why your dragging in Between gears because the t.o.b. is fully extended and just barely disengaging the clutch.
T-Man (09-06-2019)
Same thing I said but more detail
C0balts5 (09-06-2019)
SSilverSS
10-28-2014 01:00 PM
