Construction Glue on my SS Lip!!!
What can i do to take it off without removing the paint??????...Long story i was putting it to
hold mylip because it was falling off now its all spread out
It's called Valvoline Panel 50 or Panel 60, 3M Duramix is usually more expensive , either way valvoline makes the tubes for 3m but depending on the time frame you have to work with will decide what one you get .. I like the fast curing panel 50 , they require a gun you might be able to rent from an auto body supply store.
Trust me....This stuff is stronger than those clips could ever dream of being , You can use whatever you want to fill in the gaps like pieces of plastic and just glue the crap out of it with panel bond ..
To get it off you can sometimes use a heat gun or use a plastic wedge tool that can "chip off the larger pieces of glue" sand and repaint it after using the right glue and Clamps .. be sure to use wood planks with the clamps to spread out the surface area pressure
If you look closely you can see what I mean by spreading out the load of the clamps , that panel bond doesn't **** around.
u lost me man lol i have a few of the clips on the actual lip broke and im just tryin to get it to stay on to my bumper i just wanted something quick and easy to fix it or atleast keep it held to my bumper and not hanging
I used construction glue to put my lip on the car, you cant even notice, and I promise its stronger then those flimsy stupid tabs as well.
When I got a little on the paint, I QUICKLY wiped it up with some Varsol then cleaned the paint after with soap and water.
