For discussion of all things Powell!!
#627
Pittbull, I checked all the F23 mounts we have here, including an old old one, in the jig. all the same. so next item. did you try dropping the tire pressure and if so, did it make a difference? In your first email to me you said "albeit with less wheel hop" and now you say it hasnt changed. So I am looking for things that you can try via remote internet that do make a difference. Tire pressures is one such thing. thanks
#630
so you have the update here; when you email me with the tire pressure results I will reply to you, but please keep in mind that tomorrow is a busy day being Monday and there si lots of shipping to get done.
#631
#632
no problem. Just so you know, I worked Saturday and Sunday about 12 hours each day on customer car emergency issues, and cut the grass, and managed to deliver an engine block and option B to various customers on the way to a family dinner . I logged on half an hour ago and saw your post.
#635
Huh? no. welding?
pull the pcv nipple and tap the rocker cover is preferred for a nice install. Depending on the inlet tube, a weld in /epoxy in/ push in fitting ; mount the seperator, bracket and hardware provided, and change the dipstick for the new one provided. If you have a laminova thats the longest pita part.
This is the Redline install. I have changed the hose routing in and out but thats the basic set up.
This is a threaded port on an LSJ cover
this is the redline set up to a stock Redline inlet tube:
This is a cobalt set up line to the inlet tube
the cobalt bracket/ same things the line in /out has changed. And a return line check valve is now included.
A Kappa set up has been done as well for those LNF equipped models.
#637
#640
Your situation requires a check valve, they came in yesterday, i tapped them last night, have to go get fittings for them later tomorrow after a pulley swap, and then I can ship them out. plug and play
#645
give me the details on what you purchasedd and from whom. They are put together with bolt plates, and I need to know the generation of UCR to answer you, as we went to a jig assembly . thanks
#649
I got the ucrs from rootbeer. They have 1 big plate 2 small plates and a bolt per side
#650
