For discussion of all things Powell!!
Old 10-06-2013 | 08:49 AM
  #751
Powell Race Parts's Avatar
Originally Posted by kdub1492
Hey John,
I have emailed Gloria 3 separate times about the check valve for my PCV system and have not heard anything back. I'd like to get it while everything is out of the car. Hope you can get back to me soon so I can get it in the car.
Btw the valves looked great after 5k miles with the PCV system, little to no buildup
weird. please email me or text me and I will make sure it zooms out to you. Happy for your results. You have a good thing going on there for sure
Old 10-06-2013 | 12:25 PM
  #752
kdub1492's Avatar
Ok thanks John, what is your email? I olmy have Gloria's at the moment.
Old 10-06-2013 | 12:27 PM
  #753
Sox-Fan's Avatar
Got Brakes?
john@powellraceparts.com
john@powellraceshop.com
Old 10-06-2013 | 12:30 PM
  #754
kdub1492's Avatar
Thanks Sox!
Old 10-07-2013 | 07:49 PM
  #755
09TcSedan's Avatar
received my parts in the mail today! but i do have a couple of questions.
1) what do i do if my bolts for the current CAB's are seized on and i end up cutting them off,or some way get them off and they are not reusable?
2) what is the little black spacer for? is that for one of the bolts for the for the front mount?
3) what is the small aluminum spacer for that looks like an A?
4) does anyone know what size the axel nut is? and when putting the axel nut back on,what should i torque it to?
Old 10-07-2013 | 07:52 PM
  #756
please read the how to emailed to you. The installation is relatively simple, the steps must be followed in order to avoid unbalancing the mount set. The bolts for the cabs should not be seized, but if they are follow the information provided on the cab thread i started. I can find the link if you cannot.
Old 10-07-2013 | 07:57 PM
  #757
PM me your email 09tcSedan so I can check the outbox and make sure you got the how to. thanks I just checked if your email begins with billy those how to;s for cabs and mount were emailed Monday 30 September. So you should have it please let me know thanks.
Old 10-07-2013 | 08:00 PM
  #758
09TcSedan's Avatar
****! i forgot you emailed me those,John. haha mondays!
Old 10-07-2013 | 08:17 PM
  #759
Phew thought it was me. Now i got Gloria mad at me for not doing it lol
Old 10-07-2013 | 08:24 PM
  #760
https://www.cobaltss.net/forums/susp...shings-301627/
haha the last post on this thread was ....YOU...lol
I had an Impala today with seized cradle bolts. Normally we pour some good oxy/acetylene heat to it, but I think the way I described it works well for you cobalt guys... risk of fire and stuff like that makes it problematical to bring out the cutting torches...
Old 10-07-2013 | 09:47 PM
  #761
09TcSedan's Avatar
The only source of heat I have is a small hand held torch haha
Where do I get replacement bolts if I destroy the stock ones?
EDIT: i found a part number and im hoping my friend (who is a parts guy at a dealership) can get them in a day or 2. id like to have them just incase **** hits the fan.
i wana make sure i have everything i need to atleast attempt to get this done in 1 day. along with installing my front powell mount too!
Old 10-07-2013 | 10:25 PM
  #762
ced. I carry lots in stock should send them with cabs lol
Old 10-07-2013 | 10:32 PM
  #763
09TcSedan's Avatar
in the control arm in this picture,the mount in the middle of the control arm,kind of hard to explain it haha but what is that part called?
haha i guess i should have asked if they came with the new CAB's.
no big deal.
Old 10-07-2013 | 10:37 PM
  #764
yellowsupercharged06's Avatar
Its the leading bushing, the circle one( which i think your saying you bought) is the trailing bushing
Old 10-07-2013 | 10:48 PM
  #765
09TcSedan's Avatar
yea,i bought the trailing bushing. the one pictured on the far right of the control arm. was just curious as to which one was in the middle of the control arm. pretty new to all these parts.
Old 10-07-2013 | 11:08 PM
  #766
Yeah there listed on the first page right under the T CABs, the L CABs are the ones you are asking about there listed at $249.
Old 10-10-2013 | 09:37 PM
  #767
09TcSedan's Avatar
Does anyone know the axel nut size? And any list of tools needed. I looked thru the powell instructions and didn't see any. My friend just wants to know so he can grab all the tools from his tool box at work.
Thanks!
Old 10-10-2013 | 09:53 PM
  #768
^^^ you dont need to remove the axles to change the control arms or cabs...36 mm for an LNF
Old 10-10-2013 | 10:19 PM
  #769
09TcSedan's Avatar
I thought you needed to remove the hubs and all that stuff.
Old 10-10-2013 | 10:40 PM
  #770
09TcSedan's Avatar
just looked at a how to and got the picture. just making sure i know what i need to do before starting this project this weekend.
Old 10-11-2013 | 08:17 AM
  #771
Staged07SS's Avatar
Administrator
Administrator
Nope. None of that is required.
Old 10-11-2013 | 08:54 AM
  #772
bmxracerchamp12's Avatar
its just 4 bolts then they come out
Old 10-11-2013 | 11:45 AM
  #773
09TcSedan's Avatar
Sweet. Order a couple #11589009 bolts just incase the stock CAB is seized onto the bolt.
I've never messed thos suspension before other than putting lowering springs on. After reading the how to, it don't seem to be too difficult.
Printed out Powell's instructions and ordered bolts today.
Can you pick up that loctite stuff from any auto parts store? I've got anti seize but in the directions it says to put loctite where the cab goes into the control arm.
Old 10-11-2013 | 11:53 AM
  #774
Yes, just walk in and say you need some loctite, does the how to call for blue or red loctite?
Old 10-11-2013 | 11:59 AM
  #775
good luck with it, just make sure those bushings get pressed in correctly.
