For discussion of all things Powell!!
Old 02-10-2014 | 12:58 AM
  #926
rico's Avatar
redlines are longer unless u upgrade the arms etc.
I'm planning to put the lsj cobalt arms on my 04 redline and the fe5 struts with the cobalt springs and conversion
Old 02-11-2014 | 11:34 PM
  #927
rico's Avatar
So moog ones that are for the redline is my best choice ?
Old 02-18-2014 | 06:39 PM
  #928
09TcSedan's Avatar
anything i need to know for installing powell's YYZ v3 springs? between me and 2 of my friends,we have a set of sportlines installed in my old LS in a little over an hour. it was pretty cut and dry.
whats the non spring compressor way that ive saw in other YYZ threads? it didnt really give a statement on what the method really is.
Old 02-18-2014 | 08:44 PM
  #929
Powell Race Parts's Avatar
jack under the control arm. loosen top nut (21 mm) before you jack it up. use the jack under the control arm as the spring compressor
Old 02-18-2014 | 08:46 PM
  #930
best choice is all lsj/lnf parts up front - bar, arms drop link shocks struts etc . new top mounts for redline
so listen lol. lsj drop links so long as you change the front bar to lsj/lnf
Last edited by Powell Race Parts; 02-18-2014 at 08:46 PM. Reason: Automerged Doublepost
Old 02-18-2014 | 11:47 PM
  #931
EmperorJJ1's Avatar
still have that UCR hardware john? not sure if you guys got my last e-mail but havent herd back
Old 02-19-2014 | 12:14 AM
  #932
i have half of it and its such a colosall cf working and organizing I still have to either give up and make more or find the large plates. i dunno. i will make more. lol its crazy bear with me thanks
Old 02-19-2014 | 12:18 AM
  #933
EmperorJJ1's Avatar
lol ok cool just didnt want you to forget about me
Old 02-19-2014 | 12:21 AM
  #934
i think i forget about everything its a non denominationa/ open source/all inclusive sort of thing lol
Old 02-19-2014 | 12:25 AM
  #935
EmperorJJ1's Avatar
lol ur good man im still somewhat scared installing these things. ive been wanting them for forever so im excited but still somewhat scared
Old 02-19-2014 | 08:09 AM
  #936
they really are easy to install. its just a long job, you should remove the seats and lift the carpet up to avoid misery drilling through the wiring harness ( short cuts dont always remain short cuts) and you must spring the bux and buy a step drill bit ( Unibit) mine cost 65.00 dollars and is still good after many many installs. Cheap ones wont even last the job lol... the metal that GM uses the two sided zinc coated stuff, for crash beams and strutural stuff near seat belt anchorages etc is very hard and strong.
Old 02-19-2014 | 08:47 AM
  #937
EmperorJJ1's Avatar
damn good looking out. i have the cheap ones from HF but never bought an actual uni. always wanted one but the shop closed before i could buy one.
Old 02-19-2014 | 09:04 AM
  #938
armcclure's Avatar
The HF ones do alright but you HAVE to go slow and keep oil on them.
Old 02-20-2014 | 09:42 AM
  #939
09TcSedan's Avatar
So I received my YYZ's. I still haven't put my powell CAB's in but would it make the CAB installation any easier with the front struts out of the car? I plan on doing it on a Saturday, tare the car apart and install the YYZ springs, CABs and powell engine mounts.
Spring can't get here soon enough. All these parts staring me in the eye.
Old 02-20-2014 | 10:40 AM
  #940
armcclure's Avatar
Leading or trailing
Old 02-20-2014 | 10:46 AM
  #941
either way you should not attempt to install or change springs with the arms bolted up in position if you have trailing cabs; as the " over-rotation" the soft OEM trailing cab provides permits the arm to drop down to clear the ball joint out of the knuckle, then a proper spherical joint restricts that over rotation.
Therefore all the how to's I write that are provided, stipulate that the leading control am bushing bolts should be loose, to allow ease of assembly of the balljoint to knuckle and the strut to knuckle.
Biggest issue with installs appears to be folks not reading the instructions, or instructions not being written clearly enough for folks to understand. The other big issue with online forums and social media, as that most car enthusiasts spend money modding their cars, but little to no money on workshop manuals and special service tools.
Old 02-20-2014 | 10:47 AM
  #942
09TcSedan's Avatar
I believe they are the leading ones. Im not to familiar at all with CABs. I have the instructions that Mr. Powell sent me. I haven't looked at them in a while but I'm making sure I know the easiest and best route to go about installing them.
Edit: I'm almost positive the new powell CAB's I ordered are for the rear of the control arms. Assuming those would be the trailing CAB
Old 02-20-2014 | 10:50 AM
  #943
09TcSedan's Avatar
It may have been in this thread or maybe another one. I took the car into a dealership and my friend was the tech who checked it over but he said my CAB's were toast. John pointed me in the right direction and shipped me out parts haha
Old 02-20-2014 | 11:54 PM
  #944
colodude18's Avatar
This is what mine looked like when I was trying to install my new Koni struts and YYZ's with bolted down control arms and Powell trailing bushings. Fortunately John answered the email I sent him at 9PM within minutes and after loosening the tcab bolts everything lined up wonderfully
Old 02-23-2014 | 05:20 PM
  #945
09TcSedan's Avatar
Hmm. Last time I installed springs in a cobalt was probably 4 years ago. I don't remember having any problems, just jacked the front of the car up, got the struts/springs out. It was fairly simple. Me and 2 of my buddies had it done within about an hour.
Idk how much different a 07 ls suspension would be compared to a SS/tc
Old 02-23-2014 | 09:31 PM
  #946
andrewcarr1993's Avatar
Practically the same but with disk brakes on the rear beam and better shocks and shorter stiffer springs to start.
Old 02-23-2014 | 10:21 PM
  #947
09TcSedan's Avatar
so would it be easier to install the tcab's before installing the yyz springs?
Old 02-23-2014 | 10:46 PM
  #948
I don't think it'll make a difference the order.
Old 02-24-2014 | 09:36 AM
  #949
armcclure's Avatar
Yeah.. You have to take the arm off so it's easiest to do them at the same time.
Old 02-24-2014 | 11:39 PM
  #950
cfsnipers's Avatar
I'm so happy I don't live all that far from you john. Look forward to giving you a bunch of my money on the 8th! And then on the SSKev's place to give him a bunch too lol
