For discussion of all things Powell!!
Old 06-25-2014 | 02:48 PM
  #1201
BA89's Avatar
For installing the TCABS what size arbors are needed to press out the old ones and press in the new ones? Want to make sure I have all the right tools on hand.
Thank you
Old 06-25-2014 | 02:55 PM
  #1202
armcclure's Avatar
The closer to size the better. John and I both use tools that I custom made.
Removal can be rather sloppy, they come out easy. For install you MAY be able to find a large impact socket that can fit in the groove of the tcab without damagin the boot, but be VERY careful. Everything needs to be 100% lined up square. And freezing the cabs overnight makes a BIG difference.
On a side note, I cannot wait to get my UCR's installed. Too bad I have to fix the Trans and turbo first
Old 06-25-2014 | 03:33 PM
  #1203
andrewcarr1993's Avatar
The under car rails aren't too hard, especially since I'm sure you have better equipment and knowledge than me and my friend that took us probably 6 hours.
Old 06-25-2014 | 06:58 PM
  #1204
colodude18's Avatar
Are the holes as hard to drill as those in the rear crash bar for the tow hook? That thing was a ****, even with an 18V drill with a spare battery and titanium drill bits!
Old 06-25-2014 | 07:00 PM
  #1205
colodude18's Avatar
Thank you
Bring your control arms to NAPA. They replaced my TCABS for 40 bucks.
Old 06-25-2014 | 07:07 PM
  #1206
I was using an industrial drill and it was a PITA but not the worst, just make sure you're using sharp bits and drill the holes in the right spot.
Old 06-25-2014 | 07:10 PM
  #1207
What speed where you using? Metal likes it nice and slow
Old 06-25-2014 | 07:22 PM
  #1208
Lol i drilled through my crash bar and the **** started glowing red hot
Old 06-25-2014 | 08:09 PM
  #1209
Powell Race Parts's Avatar
read the instructions lol. UNIBIT. STEPDRILL. XMAS TREE DRILL BIT. whatever its called, buy the good ones ( mine cost 65.00 each) they work and last forever. Drill bits are difficult I use black/gold for a starter hole. like andrew carr says, makes it ez
eCaulk says slow. hes right. and cutting fluid as well .
Amazon Amazon
irwin make some good things i hope
Old 06-25-2014 | 08:23 PM
  #1210
Amazon Amazon
I've had good luck with Irwin bits, the step bit def makes a huge difference.
Although if you don't have one slow and light pressure with cutting oil will work, takes a lot longer but still works
Old 06-26-2014 | 01:21 AM
  #1211
colodude18's Avatar
Amazon.com: Irwin 10233 Unibit3 1/4-Inch to 3/4-Inch 3/8-Inch Shank Step Drill Bit: Home Improvement
I did read the instructions John, and I did buy a Unibit! But all Home Depot had was Milwaukee brand. Good news it was made in USA. Bad news it lasted 3/4 of a hole. Maybe my drill speed was too high. Maybe the bit was crap. I Switched to titanium bits, using used engine oil (lol) as lubricant.
Now i know. When I get the UCR I'll get a proper unibit
Old 06-26-2014 | 01:25 AM
  #1212
I happened to get an Irwin at a local hardware store chain and it worked great for me.
Old 06-26-2014 | 01:47 AM
  #1213
i got a surprise from mr. powell today
in the undercover package from CED
i was like...i didnt order anything
Old 06-26-2014 | 01:51 AM
  #1214
Steering wheel adapter?
Old 06-26-2014 | 03:42 AM
  #1215
tranny mount insert hehe
Old 06-26-2014 | 10:18 AM
  #1216
ya I always thought that Milwaukee was a stand up brand. Not any more . Garrett or Starrett or something was what I buy. 65 bux. but i do a lot of them. The only thing I need to master is to avoid the shower of sparks and metal shavings (hot) that fall and burn my arm lol
Old 06-26-2014 | 10:19 AM
  #1217
Whitnith's Avatar
John do you have a separate thread somewhere about the license plate bracket? I'm not finding one... I was gonna throw some pics up.
Old 06-26-2014 | 10:20 AM
  #1218
I dont think so. Its buried in here so perhaps you would start one? thanks very much
Old 06-26-2014 | 10:23 AM
  #1219
Whitnith's Avatar
Will do. I'll get some more pics then and start one.
Old 06-26-2014 | 10:47 AM
  #1220
the how to has the dimensions in it iirc
Old 06-26-2014 | 10:52 AM
  #1221
They make hot-not sleeves (google it) might be a bit extreme and some simple leather welding gauntlets could take care of that.
I wonder if the quality of stuff solid at big box stores (like Lowes and Home Depot) is different than other locations. I know that much is true for the cabinets and kitchen/bath products.
Old 06-26-2014 | 11:00 AM
  #1222
ya I know . lol Ii got nomex sleeves from racing . its just i never put them on until its too late lol
Old 06-26-2014 | 12:39 PM
  #1223
Omiotek's Avatar
Sterret
Old 08-08-2014 | 10:59 PM
  #1224
Viperoni's Avatar
So I installed Powell's latest rotated front motor mounts along with a stock LNF rear mount:
Initial impressions are that I can feel the engine a lot more at idle and up to ~1500rpm, not much more between 1500rpm-3000rpm, and about the same as the tired, stock mounts after 3krpm.
No noticeable increase in cabin noise, but I only had it out for a short drive so far.
Hopefully the mounts soften up in a couple weeks.
No more rocking back and forth for the motor and tranny though!
Old 09-02-2014 | 01:48 PM
  #1225
^^^great work. Redlines rock
