For discussion of all things Powell!!
#1276
He also claims Powell went back in time and copied TTR's rotated mount design... So his words are worth sawdust to me.
#1277
Thanks John, I agree, redlines do rock!
An update on the mounts, I've driven over 1000 miles on them and they've broken in and I do feel a lot less vibration in the cabin now. Not to say that there was much to begin with (I've had cars with all 3 or 4 mounts were hard poly), but it was definitely noticeable.
Now it's very very smooth - not quite as smooth as the original mounts, but a very small price to pay for keeping the engine in the right place much better.
It took a buddy of mine 15-20 minutes of driving around in the city to notice a difference, and it was at idle.
#1278
#1279
#1286
#1292
I agree. For some reason, mine looks lower than others. I dig how it looks but wish it was a hair higher as my Hahn exhaust (early production model) is the one that wasn't designed around lowered cars so it hits the rear torsion beam sometimes.
Yes, newer FE5 struts/shocks installed around the time of that picture.
#1294
#1300
If you are lucky the pinion will lift out with the bearing. If you are unlucky you will need to pull it. I had to machine a plate to enable that. If you use a lever to pry on it the teeth may chip. I had a guy buy a set of gears off the forum and send them to me.. One tooth was
chipped It only takes one tiny chip lol
