For discussion of all things Powell!!
Old 07-24-2015 | 12:55 PM
  #1401
EmperorJJ1's Avatar
i think thats what the issue is the h/e is in the way. Im not dropping that lmao cuz then im guna have to un hook the hoses and ****.
i wonder if one of those flexible extensions will work
flexible extension and hard thick ass metal dont go together well.
Old 07-24-2015 | 01:04 PM
  #1402
Dipped_Cobalt's Avatar
yeah, I didn't think so....flexible is not an option, with the hardness..nah, accident waiting to happen
Old 07-24-2015 | 01:08 PM
  #1403
Yeah flexible isnt going to work, you have to put some pressure on it. You might be able to pop the grill out and flex the bumper enough
Old 07-24-2015 | 02:00 PM
  #1404
yellowsupercharged06's Avatar
guess im going to have to see then if the extension from behind the lip gives me a straight enough passage.
Old 07-24-2015 | 02:44 PM
  #1405
even if angled, since your gonna use a bolt/nut might work.
Old 07-24-2015 | 02:51 PM
  #1406
07blackg5's Avatar
Slobodan Milošević
why not just pull the bumper? it's not like it's difficult.
Old 07-24-2015 | 02:52 PM
  #1407
very true, as I said above, that's what I recommended. plus other than tow hook im changing grill and installed retros im pulling bumper before I redip the car.
Old 07-24-2015 | 03:18 PM
  #1408
my luck putting it back on its guna be all cocked eyed lol
Old 07-24-2015 | 03:22 PM
  #1409
I thought the same thing, but when I removed it, it was so easy to re-instasll.
couple bolts and push pins, your done.
Old 07-24-2015 | 04:16 PM
  #1410
I took off the bumper to install my front tow hook, although im not to big fan having the mount touching the intercooler since i have the zzp one maybe on stock intercooler it would work and have some clearance
Old 07-24-2015 | 04:22 PM
  #1411
How does it touch the intercooler? (shift it closer to the center)
Old 07-24-2015 | 05:39 PM
  #1412
I guess the way i did the holes is touching my intercooler. I drilled the holes next to the hole that powell says to use and when i was reinstalling everything i was touching the intercooler, and im not really liking it im just going to buy a new crash bar and redrill the holes before i end up with my intercooler with a hole
Old 07-24-2015 | 08:18 PM
  #1413
No need for a new crash bar
Old 07-24-2015 | 08:44 PM
  #1414
I could move it more to the right side of the car but i screwed up doing the first set of holes lol so had to make another 3 dont have much room unless i center the bracket
Old 07-26-2015 | 11:48 PM
  #1415
northvibe's Avatar
what is the recommended brake fluid for daily with track use?
Old 07-27-2015 | 12:04 AM
  #1416
You could use dot 4
Old 07-27-2015 | 09:07 AM
  #1417
r1owner's Avatar
You could use dot 4
You SHOULD use DOT 4.
Old 07-27-2015 | 09:47 AM
  #1418
northvibe's Avatar
Is there a brand though?
Old 07-27-2015 | 10:05 AM
  #1419
RyBread761's Avatar
I use MOTUL RBF 600
Old 07-27-2015 | 10:14 AM
  #1420
I use ATE Super Blue / Gold .... best stuff out there.
Old 07-27-2015 | 10:17 AM
  #1421
northvibe's Avatar
Oh ya, and you change the color so you can see. I think Apex used that as well. Awesome. Thanks guys! I have a track cruise coming up, but the pedders and stock suspension is blown. CED trip took some shavings off the tires. I still need to roll the fenders.
Also Powell has new brake air ducts! the bolt to the control arm. Need me some of them. Hopefully john or glo can post up some pics
Old 07-27-2015 | 10:18 AM
  #1422
qfe
best for the moneys, best for performance > MOTOL RBF 600 but its double the cost of ATE Super Blue/Gold for an extra 50F or so boil protection. So daily driving its not needed and even most who track their car don't need it
Old 07-27-2015 | 10:25 AM
  #1423
r1owner's Avatar
I use ATE, I didn't think you could get the blue anymore...
Old 07-27-2015 | 10:32 AM
  #1424
Amazon.com: ATE 706202 Original TYP 200 DOT 4 Brake Fluid - 1 Liter: Automotive Amazon.com: ATE 706202 Original TYP 200 DOT 4 Brake Fluid - 1 Liter: Automotive
Old 07-27-2015 | 10:35 AM
  #1425
northvibe's Avatar
I guess that is amber color..... or the questions answer say it is.
