For discussion of all things Powell!!
Old 08-24-2015 | 12:18 AM
  #1576
colodude18's Avatar
Originally Posted by ECaulk
This is Powells thread, keep other **** out of here
qfe
Old 08-24-2015 | 08:52 AM
  #1577
Powell Race Parts's Avatar
There are three distinct pathways for PCV control on an LNF. Please check out my stuff on this on the LNF gunk thread.
This pathway the hose addresses is THe FRESH AIR INTAKE that supplies fresh air ONLY into the crankcase via a metered check valve from the intake tract post MAF to the rocker cover and then down to the crankcase. The purpose of introducing metered fresh air is to reduce NOX emissions; I also beleive it helps protect against sludge buildup.
The other two pathways are for blow by gas recirculation. The seperator is inserted in the primary line to seperate oil from blow by, and return it to the crankcase.
v.2 used a check valve in the return pathway as GM's original premise that the PCV and the cranckcase ALWAYS pulls negative pressure turned out not to be the case.
The third pathway, is out of the crankcase via two seperator passges in the rocker cover mezannine . then out through a pcv valve in the inlet manifold to the inlet plenum before the runners to the inlet ports.
Our v.3 system eliminates the off boost vacuum return of blow by gasses to the inlet manifiold directly. Updates are possible it just takes some careful work and some fittings with an extra hose.
Old 08-27-2015 | 08:43 AM
  #1578
YelCal7's Avatar
Old 08-27-2015 | 09:37 AM
  #1579
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by YelCal7
You gonna show what it looks like how to remove pcv valve in intake manifold ? Or We gotta pay to see it ?
There are some pics around, and maybe even in this thread of it installed.
Search the how to section, maybe some one made one for the install.
Old 08-27-2015 | 09:43 AM
  #1580
If you can't figure it out, pay the man since he figured it out.
Old 08-27-2015 | 10:58 AM
  #1581
YelCal7's Avatar
Old 08-27-2015 | 11:04 AM
  #1582
YelCal7's Avatar
Old 08-27-2015 | 11:27 AM
  #1583
I already had it all figured out and I know where to get it. I'm talking about his new version of oil seperator and get the idea from there. But there's nothing wrong with his current versions.
And thats what I'm talking about. If you can't develop it yourself then pay him for it. Don't expect to see photos of things so you can just copy them and not fund the man that developed them.
Old 08-27-2015 | 11:37 AM
  #1584
YelCal7's Avatar
Old 08-27-2015 | 11:45 AM
  #1585
Given your prior posts about figuring it out for cheaper, if you can't figure out how it works without directly copying Powell, buy one. If you don't want to take the time to figure out what the PCV in the intake mani looks like, buy the separator from Powell. If you want to build your own, build your own but don't expect handouts from John.
Old 08-27-2015 | 11:50 AM
  #1586
YelCal7's Avatar
Old 08-27-2015 | 11:53 AM
  #1587
LOL! Oh, I am sure that you're not ? :/
No idea what this means what so ever. I have Powells separator already installed...actually one of the first ones installed
Old 08-27-2015 | 11:55 AM
  #1588
YelCal7's Avatar
Old 08-27-2015 | 12:05 PM
  #1589
umrdyldo's Avatar
Someone already tried that and it was decided that Powell is doing us a huge favor by developing this. It can't be recreated easily and it's not worth the time.
Old 08-27-2015 | 12:09 PM
  #1590
That's what I thought, You know exactly what I meant.
No I honestly don't.
Old 08-27-2015 | 12:10 PM
  #1591
And it looks even better than the Lingenfelter kits do
Old 08-27-2015 | 12:11 PM
  #1592
heeter_33's Avatar
Is the newest update of the separator out yet or is it still in development?
With the Canadian dollar so low, I may as well just be buying my Powel parts right now haha.
Old 08-27-2015 | 12:38 PM
  #1593
JapEatr's Avatar
South Central *********
I need a few powell roll pins
Old 08-27-2015 | 02:32 PM
  #1594
YelCal7's Avatar
Old 08-27-2015 | 02:37 PM
  #1595
YelCal7's Avatar
Old 08-27-2015 | 02:53 PM
  #1596
Read carefully
I've never taken a hand out from John if that's what you're trying to imply.
Old 08-27-2015 | 02:59 PM
  #1597
Viperoni's Avatar
Powell's roll pins are better than the stuff you get from GM? (double roll)
Old 08-27-2015 | 03:06 PM
  #1598
YelCal7's Avatar
Old 08-27-2015 | 03:29 PM
  #1599
Neither do I, I just made it clear to you few posts back.
Then why do you need a step by step install guide?
Old 08-27-2015 | 03:32 PM
  #1600
YelCal7's Avatar
