DP w high flow cat, wideband questions
I have been searching for some info and can't find it. Is there a after market DP with high flow cat with a extra spot for the AEM wideband sensor. Is this something I need a shop to weld in for me? What is the easy way to do this?
I'm going to check into the new one.
Looks like for about 250.00 shipped I can get the ZZP.
The ZZP uses a Magnaflow high flow cat.
Everything is stainless, even the flanges.
Now the next question is, since I have GMP manifold, and GMP exhaust. The 2.5" would be best right? What is the point of going 3" if it has to flow back into a smaller exhaust? I could go with the 2.5" ZZP DP with all hardware needed (gaskets) with the Highflow and the extra bung for the AEM wideband.
Going to check into the price and stuff with the new Vender.
Yea, so here is the link to the rebel one: http://rebelautoworxs.com/product_in...products_id=33
Looks like a real good DP and cat but its alot more expensive then the ZZP. What you all think?
Bump, anyone else with good info on the best DP w/ high flow for my set up?
n20saturn
09-30-2015 12:26 AM
