Engine mount help!!!
Old 02-23-2016 | 10:30 PM
germbruhh's Avatar
Not Work Safe Engine mount help!!!
Hello all I need some input on engine mounts. This past weekend I had all 3 mounts replaced and now I have excessive vibration and noise that I didn't have before. I bought the new mounts off ebay at a low price, could that be the reason. What do you guys suggest I can't deal with the vibration.
Old 02-23-2016 | 10:36 PM
cluelessk's Avatar
You got what you paid for.
Old 02-24-2016 | 11:08 AM
Sl0wbaltSS's Avatar
It's a racecar, and that is what racecar is.
Old 02-24-2016 | 11:24 AM
Haven07's Avatar
With any new mounts they need a few days to settle in before the vibrations subside. That being said, never buy eBay mounts. Bad quality, you really get what you pay for
Look into Powell and Ottp mounts, miles better just have to install them in the correct order
Old 02-24-2016 | 11:26 AM
Link to mounts you bought? Theyare probably stiffer than stock
Old 02-24-2016 | 12:18 PM
LsCobalt07's Avatar
They may eventually stop causing as much vibration but it really depends on what they're made of. I bought TTR solid transmission mounts and they caused a lot of vibrations at first but over the past year I've either gotten used to it or the vibrations aren't as bad as they originally were.
Old 02-24-2016 | 12:59 PM
germbruhh's Avatar
Here is what I bought. I have been driving it since Saturday the vibration still feels just as bad as the first day. Can you guys post a link of some mounts that I should buy. I need to get these replaced asap but Im not sure what I should be buying. I appreciate the input guys.
06 11 Chevy Cobalt HHR Pontiac G5 2 2 2 4L Motor Trans Mount Set 3pcs Auto | eBay
double clutch's Avatar
You can try to loosen the 3 bolts on the engine mount like 1 turn and drive around for a bit so the mounts can settle. I doubt thats your issue tho. The bushing are probably made of poly
Old 02-24-2016 | 11:21 PM
They look like stock mounts to me. Do you have a 2.2/2.4 auto?
Old 02-24-2016 | 11:33 PM
Same to me they look stock
Old 02-24-2016 | 11:44 PM
cluelessk's Avatar
Look stock but they're cheap.
Old 02-25-2016 | 02:40 AM
Yea i didnt click on the link. Says high quality rubber. Must just be stiff rubber like ottp uses
Old 02-27-2016 | 03:39 PM
how is this NWS?
Old 03-05-2016 | 12:36 PM
Jacque8080's Avatar
Put in your original mounts. Then replace them one at a time to figure out which one is causing the problem.
Old 03-07-2016 | 02:27 PM
Viperoni's Avatar
They're probably just made with hard rubber. Stupidly cheap in price though.
bland1
03-12-2016 08:46 PM
Olybaltss
03-09-2016 03:22 PM
Karnage
02-24-2016 09:00 AM
Jay P.
02-23-2016 12:45 AM
randerson7787
02-12-2016 04:44 AM
Quick Reply: Engine mount help!!!
