Gauges, Gauges Everywhere!
I just felt like posting some gauges up here since Autometer will be coming out with 2 and 3 gauge pillars for our cobalts very soon. Now what are we going to stuff in those holes? Feel free to add more pics of gauges.
THE LINK TO THE GAUGES http://www.superchargersonline.com/p...essories_gauge
THE LINK TO THE GAUGE PILLAR POST https://www.cobaltss.net/forums/show...news+autometer
AEM Wideband Gauge with Sensor AFR (Black Bezel/Black Face)
AEM Wideband Gauge with Sensor AFR (Silver Bezel/Black Face)
AEM Wideband Gauge with Sensor AFR (Silver Bezel/White Face)
AutoMeter Water Temp 100-250 Degrees F (Cobalt Series)
AutoMeter Vacuum/Boost Gauge 30 In.Hg/30 PSI (Cobalt Series)
AutoMeter Air/Fuel Ratio Lean-Rich (Cobalt Series)
AutoMeter Fuel Pressure 0-100 PSI (Cobalt Series)
As far as knowing when you are in range, it depends on how your car is set up. If you have 42.5lb injectors it will be different than if you have 60lb injectors etc. You have to learn what works with your setup and where you should be with boost and air/fuel ratio etc.
z28addiction
09-28-2015 12:03 AM
