GMP Manifold Directions Needed PLZ
Does anyone have a set of GMP manifold directions they could send me. Maybe get it photo copied. I could pay for shipping the 37 cents or w/e haha. I'll also pay for the photo copy. *Buckle Up Flame Suit* I just need direction to do mods to my car. Lost without directions
how can you do it wrong??? its pretty much straight up...
just undo the bolts from the header to the manifold.... and the bolts from the manifold to the downpipe.
replace gaskets and put everything back together.
yah honestly man you dont need directions for this, I dont even know what I did with mine or if I even got them. Just get your wrenches and go at it and remember to do new gaskets and you will be fine.
There's actually a pattern that you have to follow to tighten the nuts, and a specific torque to set it to, I have access to dealerworld Ill get it for you now.
EDIT: I forgot what I changed my password to, I'll get it to you soon.
Thank you. +rep
1 Post
Exhaust Manifold Replacement (RPO LSJ)
Removal Procedure
1. Reposition the positive crankcase ventilation (PCV) vent hose clamps (1, 3) at the air cleaner outlet duct and the camshaft cover.
2. Remove the PCV vent hose ends from the outlet duct and cover.
3. Remove the PCV vent tube bolt (4) and nut (5).
4. Remove the PCV vent hose/tube.
5. Remove the exhaust manifold heat shield studs (2).
6. Remove the exhaust manifold heat shield (1).
7. Remove the heated oxygen sensor (HO2S) connector position assurance (CPA) retainer.
8. Disconnect the engine harness electrical connector (1) from the HO2S.
9. Remove the HO2S clip from the bracket on the thermostat housing.
10. Remove the HO2S.
11. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle .
Notice: Do not bend the exhaust flex decoupler more than 3 degrees in any direction. Movement of more than 3 degrees will damage the exhaust flex decoupler.
12. Remove the catalytic converter to exhaust manifold nuts.
13. Pull down and back on the exhaust pipe in order to separate the catalytic converter from the exhaust manifold.
14. Remove and discard the catalytic converter gasket.
15. Lower the vehicle.
16. Remove the exhaust manifold nuts.
17. Remove the exhaust manifold.
18. Remove and discard the exhaust manifold gasket.
19. Clean and inspect all gasket mating surfaces.
Removal Procedure
