Headlight bulb change.
Hey guys just running a quick question by you as far as headlights go.
As most of you know the stock head lights for the cobalt are 65/55. There is a good deal that i have been offered to get 100/80w halogen bulbs. As far as i know those will deform the harness i believe but i am not sure, either way i have heard its risky move to put those bulbs in on the stock setup. SO my question is is there a way to beef up the system so that it could with stand the bulbs. upgraded harness maybe? Im not sure, I'm lost as far as electrical stuff goes so I figured i would ask!
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
So if 100/80w will melt everything an suggestions on what a good bluish/white colored bulb would be without going Hid or having to do anything to modify the headlight?
They won't be much brighter anyway. You'll basically be getting a diminishing return. As the light down the road increases, so will the foreground light. The extra foreground light will make it harder for you to see the extra light down the road. Some of those high wattage bulbs aren't aligned properly either, so the beam pattern may be off. I actually do have a box of 9007 high wattage bulbs. The stock 55/65 watt Philips bulbs actually work better. Also, don't listen to any bad advice about putting HIDs in your stock headlights either. Just do a retrofit with HID projectors and call it a day. You won't regret it.
jcalvin1126
02-07-2016 08:50 AM
