Help Me Adjust Projectors
the projecters are a little differant than normal head lights.
the left side should be same as or a little lower than stock.
now if they are true "projecters" then the cut off beam with have what they call a "Z" line cut off....so the rite side will be higher than the driverside but the Z in the cut off will link the 2 toghater.
hope that some what helps....Mercs cut of is like that.
heres what i'm talkin bout....the change in hight from left to rite side.
https://www.cobaltss.net/forums/show...ight=projecter
check page 11
THATS WHAT IT'LL LOOK LIKE IF THEY ARE TRUE PROJECTERS! THE "TRUE" PROJECTER LENS CAUSE'S THAT CHANGE WICH IS GOOD!!!!!!!!
check page 11
