Help from the Parts Department is here.
Old 03-10-2007 | 11:10 AM
  #576
fr33k's Avatar
Originally Posted by Cobalt_Supercharged
For my car they added an extra black ring that goes underneath the cup. The cup iteself is not modified. Might look into it. Mine was all warranty, well not the chipping paint.
The black ring came from a TSB that GM put out for the problem of the fabric sticking out from underneath the switch bezels. I didn't like the looks of it so I left it out. One of the new numbers, I cant think of which side, has a wider lip than the factory one did correcting the problem without having that odd black ring.
any chance that we can order the blue material itself? i need a few yards of blue but i havent been able to color match anything yet
As far as I know, GM doesn't sell any. Some of the upholstery shops might though.
Originally Posted by Xavipheus
Am i going to be recovering my current seats?
If you want to stay ALL FACTORY you will have to remove your original seat covers and install those. The rear seats were pretty easy to do because they are the easiest to remove from the vehicle and they just clip on with J-hooks and maybe a few hog rings. The front seats were interesting to say the least. the bottoms wasn't that bad but to do the backs of the seats correctly you have to completely disassemble the seats to get the bottom fabric around the tilt mechanisms spring tensioners. That's the part that I had a little problems with.
Old 03-10-2007 | 11:53 AM
  #577
Xavipheus's Avatar
Hey Fr33k can you look up the part number on a 2001 Impala power drivers seat? Just the cushions nothing else
Old 03-10-2007 | 12:18 PM
  #578
Cobalt_Supercharged's Avatar
Not the best design, but it works. The Passenger side would be the one that's wider. The driver side was perfect, but the passenger side was about 1/4" narrower on each side of the door pull.
Old 03-10-2007 | 12:55 PM
  #579
SilverSS/SC's Avatar
GM doesnt sell just the material . Auto upholstery shops are able to get the correct factory material , they use books .....with codes and material swaths(sp?) , like paint codes thats catagorized by model year , manufacturer and car line . Good luck getting a shop order just material for you though without them doing any work on your car . Ive tried and got turned away .
If you cant get the seat covers at cost like fr33k , its cheaper by ALOT to get aftermarket covers . You can get REAL leather OEM cobalt replacements for the front and rear , in the factory stitch and pattern for under a $1000 @ leatherseats.com , and they will sell matching material to do the door panel inserts .
Old 03-10-2007 | 08:29 PM
  #580
Xavipheus's Avatar
Quote: Originally Posted by fr33k
Numbers for the blue 2 tone interior leather
Doors:
15261854 - RH Dealer Price $133.12 List Price $233.54 Trade Price $175.16
15261855 - LH Dealer Price $133.12 List Price $233.54 Trade Price $175.16
Okay just want to confirm before I order these bad boys. These are for the coupe right? Also these part numbers arent VIN specific right? Im ordering these from GM parts direct and I cant send them back if they are the wrong ones.
Old 03-12-2007 | 09:14 AM
  #581
fr33k's Avatar
There's a few different types of seats in the impalas which use different cushions and covers. If you can, I need the VIN to make sure I get ya the right numbers.
Doors:
I double checked to make sure on the numbers and they are correct. They are the black plastic with blue leather inserts for the SS/SC cobalts. They should fit all the coupe body styles. That's the same thing I done with my yellow balt. It's an LS and I added all yellow SS/SC interior to it (seats front and rear and door panels). Everything fit just fine.
Old 03-15-2007 | 02:59 AM
  #582
bigworm's Avatar
Can someone look up the part numbers for the following:
2.2L main bearings
2.4L main bearings
2.0L laminova cores and seals
Thanks!
Old 03-15-2007 | 03:28 AM
  #583
Charg'DBaltSS's Avatar
I have an '07 is there anyway I can order Recaro's for my car? The one's that came with the '06s?
Old 03-15-2007 | 10:19 AM
  #584
fr33k's Avatar
2.2L main bearings
2.4L main bearings
Thanks!
The 2.2 and the 2.4's use the same main bearings.
12591092 - BEARING KIT-CR/SHF
Dealer Price $16.99 List Price $29.81 Trade Price $22.36 each
GM does not sell whole seats for some reason. The only way is to buy each piece and make a seat and that would be really expensive.
sorry.
Old 03-15-2007 | 12:08 PM
  #585
thought's Avatar
Another way is to just buy even better Recaro seats from Recaro ;-)
Old 03-15-2007 | 01:30 PM
  #586
Red07SSNA's Avatar
Can you give the part numbers for the fillers and attaching hardware for the SS front Fascia3?
Items 10, 11 , and 12 in the exploded view.
Thanks!
Old 03-16-2007 | 09:14 AM
  #587
fr33k's Avatar
Thanks!
10 - 15248110 - BRACKET ASM-FRT BPR FASCIA OTR RH
10 - 15248111 - BRACKET ASM-FRT BPR FASCIA OTR LH
Dealer Price $41.20 List Price $69.83 Trade Price $52.38
11 - 11609406 - SCREW ASM - RND LARGE CROWNED WA HD TY 1A M4.2x1.41x20
Dealer Price $0.36 List Price $0.62 Trade Price $0.48
12 - 11513599 - NUT 4.2 1.41 U-SH PRV TQ M/TH
Dealer Price $2.20 List Price $4.41 Trade Price $3.09
Old 03-16-2007 | 09:46 AM
  #588
EmperorJJ1's Avatar
2.2 a nut? if gm is actually paying that then i c why they arent doing well finacially
Old 03-16-2007 | 11:36 AM
  #589
fr33k's Avatar
lol I know what you mean. Some bolts are known to cost over 10-15 each.
Old 03-16-2007 | 12:36 PM
  #590
Red07SSNA's Avatar
Try looking at aircraft-grade nuts and bolts -- I've seen titanium ones for $1000+
Thanks again for posting the PNs and prices!
Old 03-16-2007 | 12:42 PM
  #591
PolishPauL's Avatar
Yea are there any better ones that fit?
Old 03-16-2007 | 01:12 PM
  #592
fr33k's Avatar
np. If ya need any more, I'll try my best.
Old 03-16-2007 | 03:01 PM
  #593
Red07SSNA's Avatar
I'm preparing to install an SS/NA fascia on my 06 LS.
So far I think I have all the PNs to do it:
SS Fascia PN 12336074
Bracket RH/LH 15248110/15248111
Screw 11609406 (Qty?)
Nut 11513599 (Qty?)
Lower Grille 15773841
All other parts I should have -- is there a difference between the LS and SS grille itself or are they the same?
Is that all I need (besides paint)?
Thanks for the help again...
Old 03-16-2007 | 04:52 PM
  #594
fr33k's Avatar
the 11513599 nut and the 11609406 screw has a quantity of 10 according to my catalog. And the grille is the same for the LS, LT, and SS/NA balts. Your center grille on your facia below your regular grille is
15773841 - COVER-FRT BPR FASCIA OPG
Dealer Price $61.25 List Price $103.81 Trade Price $77.86
That should just about do ya.
Old 03-16-2007 | 05:08 PM
  #595
Red07SSNA's Avatar
Thanks....now I gotta find someone who can do a simple victory red paint job....
Old 03-16-2007 | 06:37 PM
  #596
EmperorJJ1's Avatar
oh it comes with 10 nuts? thats not as bad then
Old 03-16-2007 | 09:55 PM
  #597
Red07SSNA's Avatar
Which means it's $22.00 for the 10 nuts...
Old 03-17-2007 | 03:45 AM
  #598
EmperorJJ1's Avatar
oh hell no
Old 03-19-2007 | 08:56 AM
  #599
fr33k's Avatar
lol. yea, that price is for each nut.
Old 03-20-2007 | 01:34 AM
  #600
Any update on that GMPP muffler section?
Quick Reply: Help from the Parts Department is here.
