I need help guys
I need help guys
I bought a 2.4 intake manifold I'm looking at my 2.2 and it looks the same except where the brake booster connect 2.2 on the side 2.4 in the front.
They look the same. Now I'm thinking what would this help my car with?
Your car appears to be 07-08. Apparently the 09+ LAP manifold and the 08+ LE5 are the same volume. So as long as your car isn't a 09+ it should still show a gain. A small one, but still a gain
Yeah I got a 2007!
Most likely if you have a high idle, you might get lucky if you unplug your battery for a few minutes it might relearn idle correctly. I'd also check for any vacuum leaks before you go buying a new throttle body normally if they're bad it will put you in engine power reduced mode
Wtsf_hc@yahoo.com
06-16-2016 02:42 AM
CudaJoe
04-18-2016 11:39 AM
