LE5 or LNF?
LE5 or LNF?
So I'm in a debate with myself. I'm working on a project and am stuck until I get the block and transmission to make mounts and such. But at this point I'm stuck between building a LE5 or the LNF.
I've found the LE5 easier to obtain and very cost effective. ZZP also told me by putting a LNF crank in the LE5 would make the engine much more efficient and basically turn it into a 2.1L. Keep in my mind I plan on building both engines regardless of my decision and will have a turbo.
Now the LNF leaves me with a decent product on it's own and already has a turbo application setup. The engine is newer has many useful oil cooling features. Problem is they are hard to come by at a decent price since they are the "newer model."
Basically I'm just asking for some useful knowledge and suggestions on which route I should take and the pros and cons of both. As much info as you guys can give will be greatly appreciated!
I'm really leaning towards that setup. I really just want the block and transmission so I can get my mounts made and then paint the car. I can build the motor later. Now would the LNF head be more efficient?
