Looking for window, lock and mirror wiring diagrams.
Hi! I'm a Firebird owner doing something a little different. I've got a '90 Bird that's got a '99 Camaro's body control module operating its windows, locks, mirrors and dome light. The addition of the BCM gave me remote keyless entry, auto-down windows, retained accessory power and that cool fade-out dome light effect. All that stuff is done, and the only part of the project that I have left is the switches. I'm having to hook up Cobalt switches to the Camaro harness (long story), and needless to say nothing matches up. The problem is (and I'm sure you all are aware), Cobalt parts are not cheap. I can't get ahold of a Cobalt wiring harness I can chop up to get the switch pigtails. I found similar pigtails from different cars at the junkyard but the wire colors probably do not match up with the Cobalt's. Here's where you guys come in.
I am at a standstill until I can get ahold of a two-door Cobalt's power windows, locks and mirrors wiring diagram. I need to know what each individual pin in each switch goes to so that I can match it up with the appropriate wire on the Camaro harness. I've done countless searches over the past few months and there is just nothing out there. By the way, in the event that no one has diagrams, a few pictures of each side are much better than nothing.
Your help keeps me from having to use switches from a Saturn Ion! Thanks for your help!
Here's some of the colors for what your needing. I'll try and find actual schematics later on. These are for coupes only. And I'm using 07 as my vehicle.
Drivers door Lock switch
Pin Wire Color Circuit No. Function
A BK 650 Ground
B GY 8 Instrument Panel Lamp Supply Voltage
C WH 682 Door Lock Lock/Unlock Signal
Passangers Lock switch
A BK 650 Ground
B GY 8 Instrument Panel Lamp Supply Voltage (1)
Drivers Window Switch
A L-BU 166 Power Window Master Switch Right Front Up Signal
C D-GN 801 Retained Accessory Power Fuse Supply Voltage
D TN 167 Power Window Master Switch Right Front Down Signal
E -- -- Not Used
F BK 650 Ground
G D-BU 164 Power Window Motor Left Front Up Control
H BN 165 Power Window Motor Left Front Down Control
passengers window switch
A D-GN 801 Retained Accessory Power Fuse Supply Voltage
C BK 650 Ground
E -- -- Not Used
F BN 667 Power Window Motor Right Front Down Control
G D-BU 666 Power Window Motor Right Front Up Control
H L-BU 166 Power Window Master Switch Right Front Up Signal
A BK 650 Ground
A BK 650 Ground
E -- -- Not Used
F BK 650 Ground
C BK 650 Ground
E -- -- Not Used
agentirons
10-16-2015 03:11 AM
