Need help with zzp stg 3
Hey eveyone I got a couple questions I could use all the information I can get before I order zzp stage 3 kit
1: is anyone using there stealth heat extager,is it better then there stage 3 its only a 80 diff but is it worth it
2:has anyone in countered any problems running the 2.9 pully with the shorter belt ore should I spend the extra 110 for the adjustable tesonor
3: is the duel pass intercooler plate any good and is it necessary
I have a 06 ss/sc injen cai header down pipe and 2.5 exhaust
Hahahahah very funny y'all nigs got jokes what ever leave me alone hahahah b
So on the 2.9 pulley running the shorter belt is gonna be fine its not gonna slip of due to the smaller pulley because the smaller belt is for the 3.1 or 3.0 pully also what about the slack of the belt
You should be fine. I know people running shorter belt on 2.7
i'm running a stealth; people all warned me that it was a p.o.s. and not worth it i'm not sure why really; it is huge and sits in front of everything else unlike the stock one which is snadwiched between the a/c condensor and the radiator so i think its a good piece. worth it though? up to you really. as the guy above saisd you'd likelyyield similar differences by moving the stock h/e up front which isn't too complicated to do. the stealth sure looks nice and my temps are ok considering i'm on a 2.6 pulley lol
Best cooling mods you can do is nitrous, dual pass and option b, and opening up engine flow such as full exhaust, ported head, cams...
