Need serious help
How are you sure that its 100% the timing chain making the noise? Have you used a stethoscope to isolate where the sound is coming from? Video Link: https://www.youtube.com/watch?v=6mpNRJ7m-c8
I don't know honestly it didn't make the noise all the time only every once in a blue moon with the old tensioner so I saw that could be what was going on so I changed it and now I have the noise more often after being ran awhile
If you didn't take your valve cover off when you installed the new tension then you never released the new tensioner and that is likely what is causing this noise.
That's it I'm done with this thread.
I just looking at it timing area looks perfect no issues there but you can tell that the back cam is got issues what he did was but the cam sensor on the ohm reader and wasn't reading the way it was supposed to it's not getting enough oil to the cam and you can see the wear is different than the front cam
DANRICKARD
10-01-2015 12:08 AM
