Oil change
so on my next oil change i can put mobile 1 in my car and then use a ac delco filter, i won't need to flush my motor or anything? i have 12000 miles on it right now?
Originally Posted by hardtocope
i thought if i use 93 octane it will leave left sludge in the fuel filters and run better?
As long as you changed your oil on time you don't need to flush it, just change it like regular. Most of those oil flushes are just doctored up kerosene, do you want kerosene in your internals?
Originally Posted by css9450
At 12000 miles its almost time to change your blinker fluid too.
^definitely past due for horn fluid too. that stuff is probably grimey as hell.
They say you shouldn't use synthetic until the engine is already broken in (unless, of course, the car comes with it). However, these engines are broken in before they even get put in the car. The transmission, suspension, clutch, etc isn't, but you're not going to put oil in those.
It's safe to change to synthetic whenever you want, and it will last a long, long time. Just make sure you check your oil level and also pay attention to how dirty it is. It will likely show signs of getting dirty after 5k or so miles, but the oil itself will be fine. Change the filter, and you'd be good for another 5k. Of course, that varies depending on where you live. If you're in the dustbowl like me, you may go as many miles before it gets dirty.
As far as 93 keeping the engine clean, all gasolines have detergents in them for just that purpose. A good oil will also resist sludge build-up. (another benefit to synthetic)
And like the other guys said, don't forget to change your horn and blinker fluids.
#36
Originally Posted by rallyyellow06
Royal Purple is great but only for a short time. After about 1500 it starts to breakdown.
I just switched to Mobil 1. Best you can get and at walmart its only 20 bucks for 5 qts. Great deal!
#38
my dealer told me i definitely shouldnt go from synthetic to standard in this car...he said once i go to synthetic, i have to stay on it...
abyway...hows about me? i plan on goin mobil 1 synth for my oil change, but i havent even had my 1st oil change yet...am i still fine to change? or should i stay on natural for a while?
#39
I don't own a Cobalt yet. (I'll be ready to buy in about 1-2 months, and right now Cobalt is my #1 choice).
However, from reading your post you made it sound like you can change the filter without changing the oil. How? I thought if you took the filter off all the oil will just pour out there.
#40
#41
so should i wait till around 20,000 to change it to syntecthic?
#42
The filter is mounted up high on the front of the block, under a little cap. Unscrew the cap, and the filter comes out with it. You spill maybe 2 drops, if any. Nothing pours out.
importkiller
09-30-2015 07:18 PM
roth
09-26-2015 12:16 PM
