p0420
p0420
P0420 catalyst system low efficiency
now i got this trouble code a couple of days after putting on an ss/sc downpipe with a high flow on my 2.2 right now i have the ss/sc manifold, ss/sc downpipe with a vibrant 3 inch catback so you think mine came on because ive lost to much back pressure with the vibrant catback
thanks
thanks
Its the P0420 code that is telling you that the cat is inefficient. Of course in your case, it is non-existant. You can turn it off with HPtuners I believe.
Not on a 2.2 you can't.
You can clear the code at any autozone or Murrays or any auto parts store using an ODB-II scanner but problem is if the code default again three times it will trip the check engine light.
Moving the o2 sensor may help but I believe the real solution would to just put the stock system back on for now till you can find a more managed approach, that or run an interceptor in your car to clear the code everytime it comes on
I was refering to Micone's post.
The stage 2 tune wouldn't include your mods. You would have to get a custom tune for that.
Spacer works fine. The only thing you may have to do is cut a square out in the body where the sensor is so it will fit with the space. That's what I had to do. Spacer been in for 2 months now and no more code.
SprChrg4Life
06-20-2010 03:15 PM
