Rear Taillights
Rear Taillights
Hey i want to smoke my taillights but i have no clue how to get them off i can get the trunk ones off but the outer two i cant figure it out, i have 2 black plastic things on each in my trunk that look like if i could get off the trunk liner will come off and i can get to the lights but those plastic things dont twist off...
Backup Lamp Assembly Replacement
Cover, Backup Lamp
Tip
Press the tab on the cover to remove from the decklid.
Nut, Backup Lamp (Qty: 3)
Tip
If only replacing the bulb, turn the bulb socket assembly and pull out of the lamp assembly. This can be done from inside of the rear compartment lid, without removing the lamp from the vehicle.
Tighten
10 N·m (89 lb in)
Lamp Assembly, Backup
Tip
Disconnect the electrical connector.
Tail Lamp Assembly Replacement
Nut, Tail Lamp (Qty: 3)
Tip
If only replacing the bulb, turn the bulb socket assembly and pull out of the lamp assembly. This can be done from inside of the rear compartment, without removing the lamp assembly.
Tighten
10 N·m (89 lb in)
Lamp, Tail
Tip
Disconnect the electrical connector to remove the lamp from the quarter panel.
Cover, Backup Lamp
Tip
Tip
Tighten
10 N·m (89 lb in)
Tip
Tip
Tighten
10 N·m (89 lb in)
Lamp, Tail
Tip
i have no clue what you are talking about sry but all i am trying to do it take my 2 outter taillights out so i can Smoke them with Nightshades Spraypaint but idk how to get to the taillights to pull the whole light out.
You'll likely have to pop the plastic trim around the bottom of the trunk opening (clips, should pull right off), then peel back the liner and you should have 3x 10mm nuts holding the lens assembly in place. Once those are off the whole lamp should pop loose, you might need to nudge the bolts attached to the lamp to crack it loose from the inside.
My car you just twist off those black screws outside the liner. Then pull back the liner and you will have 2 more 10mm nuts to remove. Unplug and then pop the lights out. Pretty easy.
DANRICKARD
10-01-2015 12:08 AM
Delta coupe
09-30-2015 08:11 AM
