a SECRET TSB I thought everyone should know about
Old 04-04-2008, 09:09 AM
  #76
Edubs's Avatar
Thanks for the info fr33k.
Looks like my car falls within those dates. With the cams, I'd figure I would have already shattered the timing chain if it was a non heat-treated one. I'll keep an eye out, though. Thanks for the heads up!!!
Old 04-04-2008, 10:20 AM
  #77
SS/SCking's Avatar
Thank god for a 10/05 build date here...
Old 09-24-2009, 12:18 PM
  #78
Cefaln452's Avatar
now is this sortsa a recall or what?
Old 10-02-2009, 08:06 PM
  #79
mrfitz's Avatar
are you guys getting a "click" when engaging a gear too? like once the flywheel and clutch meet up again?
Old 11-04-2009, 02:39 PM
  #80
mrfitz's Avatar
So I posted a video of this rattle, the video is backwards but you can hear it nice and loud.
http://www.youtube.com/watch?v=8FSf0-dTFLI
Old 11-09-2009, 08:47 AM
  #81
roboticfister's Avatar
Mine does this too. I also just lost 5th gear due to a bent fork because apparently the fellow that owned it before me was a fat man and drove with his weight on the shifter cruising in 5th (bad habit) and now I have the transmission out. I figured while I have the tranny out I'll go ahead and crack open the engine and fix this. Does anyone have the part number for a replacement heat treated timing tensioner? Or maybe a website or parts outlet with aftermarket options? Sure would save time trying to talk to a moron on the phone at GM trying to track the part down.
I also think I have either a bad SC bearing going out or a weak accessory belt tensioner as I also have a on again off again squeaking noise coming from the engine bay. Kind of a chirp/squeak noise that's audible about 75% of the time at all operating conditions. That'll be a little harder to pinpoint but I'll probably start with some soap on the belt and if it goes away then I'll know it's not the SC bearings.
Old 11-16-2009, 02:59 AM
  #82
sealy's Avatar
that sucks...sounds like crap. my resonator and cat were messed up and sounded similar...but not quite. good luck.
Old 11-16-2009, 03:02 AM
  #83
ff_drift_lol's Avatar
timing chain actuator. they changed the design. I replaced mine already. could just be that.
Old 03-31-2010, 11:47 PM
  #84
Pyros777's Avatar
Originally Posted by Pyros777
Yikes. My car was built sept. 06. Hope I don't get this problem.
I think I may have this problem now. LOL
Changed the timing chain tensioner to no avail. Still have lots of rattling/ticking in the timing chain area along with the occasional stumble.
Taking it to the dealer Monday.
Old 09-07-2010, 04:35 PM
  #85
doober321's Avatar
This is happening to me! ^ what happened when you took it in? I
too get the Click sound when i shft sometimes.
Old 09-07-2010, 10:23 PM
  #86
Pyros777's Avatar
Turned out to be a combo of a bad belt tensioner plus an exhaust leak for me. Both make ticking/rattling noises.
Old 09-07-2010, 10:49 PM
  #87
doober321's Avatar
I for sure have the same problem then. My gmpp exhaust cat is all dented to **** and most likely leaking. Do I go to the dealer to have the timing chain/tensioner replaced? Warranty?
Old 09-07-2010, 10:54 PM
  #88
Frew's Avatar
jeez, first the tensioner now this
Old 09-08-2010, 01:37 AM
  #89
PrincessTurbo's Avatar
How one person can destroy a brands name.
I bet that guy was fired ..
Old 09-08-2010, 03:21 AM
  #90
Pyros777's Avatar
Just to clarify, your exhaust issue wouldn't cause this. They're completely separate issues. In MY case I had a whole bunch of things go wrong all at once. Just bad luck I guess. If you're concerned enough about it then by all means take it to the dealer.
DarrenGC
12-24-2021 01:55 PM
biniecki
10-25-2015 02:23 PM
cw383
09-30-2015 12:41 AM
Quick Reply: a SECRET TSB I thought everyone should know about
